Windows 7 Right Click Menu customization
D-11
Hi, D-11 again with my annoying questions ;) So... Is the Right Click menu open for customization? Like removing commands you don't want/need? Because always when I save pics to my HDD I click on Send Image... instead of Save As...
This is related to Firefox, not Windows so not sure why you're asking here but whatever. To get rid of certain menu entries (context menu or main menu) within Firefox, you need to download this add-on. Deselect the entries you want to be taken out and that is all there is to it
Menu Editor
Link Removed due to 404 Error
I just answered your question. Sometimes you're really vague.
So I'm stuck with the annoying thing ain't I?
Dang! Well, thank you for your assistance though it didn't really lead to anything.
Bye
Menu Editor
:eek: THANK YOU!!!
BTW I though it had something to do with Windows.
Yes,, would like to state that the Send Image and Save Image, Set as Background context menu items are default Firefox menu items. They are programed into the Software and I do not believe there is any visible settings anywhere that will get rid of them. It appears (maybe) that you would need to hack the userchrome.css or other files to accomplish what you want.
Other than maybe the add-on listed above.
Add-On = Problem solved. Case closed. I am happy. Context Menu Entries are finito
(Sorry for the blunt, overly clear, getting-my-point-across post)
Unless I missed something (Don't think I did)
