Windows 7 Screen Issue..
Leon Greybe Jnr
Hi All,
It would appear that I have a screen issue that is stopping me from playing Microsoft Flight Simulator Have a look at the attached pic) error.jpg
I have a Radeon HD6950 card with one monitor although from the picture it would appear that Windows think I have two monitors.. I have checked the display settings and everything seems to be ok. error1.jpg
How can I find out
a: what is causing this problem &
B) How do I fix it?
It would appear that all this happened after I updated my drivers. I have tried the following without any luck:
Rolling back the driver
system restore
complete uninstall of the drivers following a re install
Any help would be greatly appreciated!!! Thanks in advance!
Saltgrass
I suppose a couple of questions. The message says you need a Radeon 8500 or better. You say you have a 6950...I don't know much about AMD video cards, but is this a problem?
And what are the two images? Do you have two monitors and one image for each?
Top Bottom
