Windows 7 SD Card Reader says: Insert disk into removable disk?
1Bit
I have a 5-in-1 card reader, ive tried it in an XP computer and now my Windows 7 computer - it installs, lights up when you insert and SD card, windows plays a sound to indicate its detected, when I go into My Computer its there and its called REMOVABLE DRIVE F: - when I double click on it, it says "PLEASE INSERT A DISK INTO REMOVABLE DISK"..?
the card is from my camera and works in a USB Adapter/reader - its not write protected either?
can anyone help get this working?
thanks
patcooke
Microsoft MVP
Microsoft MVP
If your card is readable from a usb adapter/reader then it looks like the 5-in-1 reader has a problem. Have you tried it with other cards/in other computers?
1Bit
HI , Tried the reader on 2 motherboards in xp and win7 - only have 1 card but that works.. seems to be the reader as u say
