* Bugcheck Analysis *
BugCheck F7, {1080, 158b23ada282, ffffd466d2205dcd, 0}
Probably caused by : nvlddmkm.sys ( nvlddmkm+19ac76 )
Followup: MachineOwner
all you dump files were different, the first is a bugcheck 7e which causes can range from out of date bios, driver issues and hardware issues (usually graphics). The second dump file pointed to memory corruption and was a bugcheck C1 memory pool corruption whilst the last of those sent you can see above. The above means a driver over ran a stack based buffer and it's pointing to the gpu driver as the probable cause.
I have a feeling however that this is just a red herring and probably the true issue is your bios needs updating.
BiosVersion = 0301
BiosReleaseDate = 07/18/2013
The latest bios runs at 2203 and many of the updates are for system stability. Please double check I have the correct information for your model. You can find your support page here:
H81M-E - Support
Driver wise your not doing too bad and everything looks pretty much up to date. If the bios update fails to stop the bsod then we'll run the driver verifier. First though you will need to create a Recovery USB/disk. This is in case the verifier induces a bsod loop on start up.
Recovery
Creating a recovery drive - Windows Help -
Verifier
How do I fix a Blue Screen in Windows using Driver Verifier?
If the bsod stops then don't bother running the above but if you should run it and you get the bsod on start up. Use the recovery disk/usb to boot into safe mode and turn the verifier off. Post the resulting dump files.
I forgot to mention that you do seem to have some corruption within the os itself. Please run these scans:
File scans
Right click on the Start menu icon and from the revealed list choose 'admin command prompt'. Type:
sfc /scannow
press enter and await results
