- Joined
- Jun 27, 2006
- Messages
- 23,048
- Thread Author
- #1
I have Malwarebytes and Windows Defender as my protectors. I am trying to remove Trovi.com. I keep getting this annoying website with more tabs. I have tried to eliminate it several times, without luck. Every time I think it's gone, it comes back. When I Google info on uninstalling it I get several suggestions which, of course, will give me …
Continue reading...
Continue reading...
Strange you cannot remove it with malwarebytes, even manual removal is possible: http://soft2secure.com/knowledgebase/trovi
If nothing above helps, try adwcleaner
Similar threads
- Replies
- 4
- Views
- 502
- Solved
- Replies
- 1
- Views
- 594
- Replies
- 2
- Views
- 778
- Solved
- Replies
- 8
- Views
- 1K
