Windows 10 Sound card not detected
BlackJesus
Hi, I'd left my computer on over night and this morning I restarted it, after restarting i had no sound and my sound card is no longer being detected.
-sound card is sound blaster recon 3di
Here is the link for your driver
You should also run Windows update manager, that might also fix your problem.
You install or reinstall sound driver
Check your cables.. Too...
Sent from my A37f using Tapatalk
