I installed the latest RC7 today and have almost everything working. I also installed the latest realtek HD audio drivers. The output is working OK, but I can not use the input. Neither the pink or the blue jack respond to any input.
It sounds like you both need to uninstall the Realtek Drivers.. If your audio was working fine until you installed those then that SHOULD do the trick..
I had not made any changes to the drivers when the problems started, but I did finally solve the problem, found a codec compatible with windows 7 on the Link Removed site. Follow that link, click accept to the terms then dl and install the top one. it was a bit of a pain to install windows would keep asking me to allow ever 5 seconds but just keep clicking allow (seems like there's no yes to all feature).
