Startup Error Please Help Immediately :(
Yesterday, my Windows 7 has suddenly crushed after a restart. I didn't understand what happened. I haven't installed or uninstalled a program or plugged a device. The black screen about recovery comes. http://www.withinwindows.com/wp-cont...8/12/menu3.png. When I tried to restore windows it shows 0 mb partition and the C: drive is missing. It show 0 mb partition and the drive is "C:". I've tried bootrec and bootsect commands but the situation didn't change. Also I tried with a Vista dvd but it doesn't help. I've many important files in the pc, I don't have a chance to format my pc. Please somebody help..
Btw, I'm using Sony Vaio notebook.
When startup repair is done. It helps nothing but it says:
Root cause found:
No OS Files found on disk.
Repair action:partition table repair
Result:Failed. Error code = 0x490
Time taken = 672723 ms
I'm planning to unplug and plug the hdd.. Does it help ?
Can you boot windows in safe mode? Attach the crash dumps found in your C:\Windows\Minidump.
reghakr
Also I tried with a Vista DVD but it doesn't help
What exactly do you mean by this?
You're link is broken, BTW.
