theabdoul
Well-Known Member
hello everyone
and thanks for stopping by and reading the post
i got a big problem with the pc which is still 2 month old ( if not less ),
it just suddenly turns off or sometimes restarts with no reason, the pc just makes this sound like it's unplugged, i've red each and every single topic about it and still nothing helps me !
am running a
windows 7 64 bit
6gb ram 1333 2gb each one of them is that with it's own cooling
i7 1156
p-55-ud3
gtx 210
case : cooler master haf 920
ps : cougar 750 wts
1 tb grean hd and 2x laptop 250 HDs connected inside.
the problem is ..no bsod shows up ..just nothing
the pc never heats up ...i use speed fan ..t's always cool
and if ye know the cooler master haf ye know it has got lots of fans and i installed one more from the side
but i don't know what else should i say here
please i need help asap ...this is annoying me ...sometimes it even ends my work while doing something ...just like it's unplugged and all me work is gone ...
if ye need any info i will post it ..just ask for it if ye need it
cheeers in advance
apologies for not replying sooner and thanks for posting the dump. The bsod was actually caused by wininit.exe which is a start up module needed by windows. I'd update your drivers, that means all drivers like chipset, network, graphics, audio and so.. Also check for bios updates relevant to your motherboard. If your unsure on how to proceed then post back and we will be happy to point you in the right direction.
I would also either run a repair on windows itself. Change your boot order so you can boot from the 7 disk and then at the installation page choose 'Repair' instead.
Lastly, just to make sure, download malwarebytes Malwarebytes or use your own anti virus app and run a full scan of your machine.
Is it still in warranty?
Are the power cables secure, or could there be a bad connection?
Is there anything in Event Viewer around the time of the errors. The Kernel Power many times is the result of a problem and not the actual problem, although it may be a power supply situation.
Is the 1 TB green drive your primary hard drive? Have you tried disconnecting anything you do not need for testing?
Does it happen in Safe Mode?
answers in order:
no it's not
they are secure i know and am sure of that
nothing rly suspicious
what about the power supply situation ? i didn't get it ?
the HD is my main can't d/c it.
and finally
can't try that in safemode.
i meant didn't try in safe mode pardon me
the thing is
i don't know wts wrong
the pc sometimes stays for 5 days with nothing wrong
sometimes it's only 2 minutes
this is why i can't try the safe mode ...i won't know when to stop, it might last for about 10 days and on the 11th it will shutdown ....
it's rly weird
Since it seems to be random, it will be hard to track down, so I can only recommend a couple of things.
Plug the computer into another outlet.
Start watching very carefully what is going on when it shuts down. For instance, is the shutdown related to any software you run? Are there any electrical occurrences when this happens you may have noticed? Is it the same time of day?
If it continues, I would unplug it then go and re-seat all the cards and memory and check all internal connections. Leave the case open for a while.
If you can't find anything that way, you might start replacing parts to pin down the problem. The power supply is normally the easiest and cheapest, but it might be anything from a loose CPU to a bad trace in the motherboard.
i sometimes hear weird noises like something is a bit moving in there hahaha
well
is it a hardware problem ?
and i can't change each part
might it be that the power supply not taking it ?
and no it's not a software i run
and as i said not the same time at all
very random
i just had my first BSOD i don;t know why is that
but i had a third 2gb ram 2 days ago ...and this has been the second time since it was connected.
might it be the motherboard or sth ?
and btw it doesn't happen while on ....
it happens while loading fro some reason ....and it doesn't go away
it keeps there till i shutdown
it say8s at the end of it reating dump and doing something else ....and then dump done or sth like that
then just stays there till i restart it
if you post the minidump that may have been created when the pc blue screened then we can check what is causing the issue. Just check C:Windows/Minidump, zip the contents and post. If you find that there is nothing in the folder then you'll need to configure your pc to produce dump files.
See the screenshot below:
Link Removed due to 404 Error
Link Removed - Invalid URL
file: mini dump
password: huvikolileju
( if asked for any )
fine i did it
it's just waiting to get verified
i posted it 3 times ..didn't read the automated msg about the approval
There is a BSOD forum, but you can attach a file by zipping it and using the paper clip. Some folks do not like going to strange websites.
I play at reading dump files occasionally, but I do not have a .rar utility.
i use microsoft security essentials
and how do i update them
well ..the problem is i think i downloaded all of them..and then then it hpns again
so i found this software the does it for ye
i downloaded and installed it and it says i got 36 OUTDATED!!
...are they even more then 12 ?!?!?
so i click update and it happens and then when the software runs again says it up to date ..while another unregistered one says it's not!
but i don't know such things like
nvidia gt210 ...and gtx 210 i found both on nvidia's website..and i don't know which is it
second thing...i don't know all them fella
i need someone to help me with it please
just tell me the names at least and i can get them!
and cheers for the help, waiting a reply
I'd still try malwarebytes as it runs great alongside Security Essentials and would enhance your security perfectly. Also to help me further try this app called SiW (System information for Windows): http://www.gtopala.com/ . As you can see in this screenshot it will give you the information regarding your system which you can then supply to me..
I've arrowed areas that are relevant and if you could post this information I'll be able to help further with links and the like.
Your Nvidia drivers can be found here:
266.58
file: mini dump
1. Uninstall LogMeIn
2. Update Marvell SATA Controller
mv91cons.sys Tue Sep 22 17:36:37 2009
Marvell: Support
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\021611-18688-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`03213000 PsLoadedModuleList = 0xfffff800`03450e50
Debug session time: Wed Feb 16 06:56:42.315 2011 (UTC - 5:00)
System Uptime: 0 days 0:00:19.361
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck F4, {3, fffffa80070dfa00, fffffa80070dfce0, fffff8000358c2d0}
Probably caused by : wininit.exe
Followup: MachineOwner
0: kd> !analyze -v
CRITICAL_OBJECT_TERMINATION (f4)
A process or thread crucial to system operation has unexpectedly exited or been
terminated.
Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa80070dfa00, Terminating object
Arg3: fffffa80070dfce0, Process image file name
Arg4: fffff8000358c2d0, Explanatory message (ascii)
Debugging Details:
PROCESS_OBJECT: fffffa80070dfa00
IMAGE_NAME:  wininit.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: wininit
FAULTING_MODULE: 0000000000000000
PROCESS_NAME:  wininit.exe
EXCEPTION_CODE: (Win32) 0xc1 (193) - %1 is not a valid Win32 application.
BUGCHECK_STR:  0xF4_C1
CUSTOMER_CRASH_COUNT:  1
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`089a0b08 fffff800`0360ff62 : 00000000`000000f4 00000000`00000003 fffffa80`070dfa00 fffffa80`070dfce0 : nt!KeBugCheckEx
fffff880`089a0b10 fffff800`035b7a23 : 00000000`00000001 fffffa80`070c2780 fffffa80`070dfa00 00000000`002576f0 : nt!PspCatchCriticalBreak+0x92
fffff880`089a0b50 fffff800`0353f90c : 00000000`00000001 00000000`00000001 fffffa80`070dfa00 00000000`00000000 : nt! ?? ::NNGAKEGL::`string'+0x17666
fffff880`089a0ba0 fffff800`03282993 : fffffa80`070c2780 fffff880`000000c1 00000000`00000008 fffffa80`070c2780 : nt!NtTerminateProcess+0x20c
fffff880`089a0c20 00000000`7722f97a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`001afcc8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7722f97a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0xF4_C1_IMAGE_wininit.exe
Drivers:
fffff880`00f1b000 fffff880`00f72000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c3d000 fffff880`02cc7000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0fe00000 fffff880`0fe16000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`01132000 fffff880`0113d000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`0782f000 fffff880`07837000   AppleCharger AppleCharger.sys Mon Apr 26 23:54:05 2010 (4BD65FDD)
fffff880`00db5000 fffff880`00dbe000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00dbe000 fffff880`00de8000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`0142b000 fffff880`01432000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`0781e000 fffff880`0782f000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`07d79000 fffff880`07da3000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cca000 fffff880`00d8a000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`019c6000 fffff880`019f6000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c6c000 fffff880`00cca000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0145f000 fffff880`014d2000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`03c82000 fffff880`03c92000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`09496000 fffff880`094a4000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0796d000 fffff880`079f0000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`07800000 fffff880`0781e000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`0795e000 fffff880`0796d000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`019b0000 fffff880`019c6000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`07c3d000 fffff880`07c5f000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`02d67000 fffff880`02daa000   dtsoftbus01 dtsoftbus01.sys Wed Dec 22 05:19:28 2010 (4D11D0B0)
fffff880`094b0000 fffff880`094b9000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`094a4000 fffff880`094b0000   dump_ataport dump_ataport.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`094b9000 fffff880`094cc000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`094cc000 fffff880`094d8000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`03c96000 fffff880`03d8a000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`03d8a000 fffff880`03dd0000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`01189000 fffff880`0119d000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0113d000 fffff880`01189000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`014e3000 fffff880`014ed000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01976000 fffff880`019b0000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0186c000 fffff880`018b6000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`07da3000 fffff880`07db0000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`037f0000 fffff800`03839000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`03dd0000 fffff880`03df4000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`094f4000 fffff880`0950d000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`0950d000 fffff880`09515080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`094e6000 fffff880`094f4000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0196d000 fffff880`01976000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`00e5c000 fffff880`00e64000   intelide intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0785d000 fffff880`07873000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`10bee000 fffff880`10bfd000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`09516000 fffff880`09524000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bc0000 fffff800`00bca000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`07882000 fffff880`078c5000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013de000 fffff880`013f8000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01400000 fffff880`0142b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`07c5f000 fffff880`07c64200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`03df4000 fffff880`03dfb000   lmimirr  lmimirr.sys  Tue Apr 10 18:32:45 2007 (461C108D)
fffff880`00c14000 fffff880`00c58000   mcupdate mcupdate.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`094d8000 fffff880`094e6000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`07873000 fffff880`07882000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`00d9b000 fffff880`00db5000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`01836000 fffff880`01867000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`015f1000 fffff880`015fc000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f7b000 fffff880`00f85000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0119d000 fffff880`011fb000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`07953000 fffff880`0795e000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`0195b000 fffff880`0196d000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`00d91000 fffff880`00d9b000   mv91cons mv91cons.sys Tue Sep 22 17:36:37 2009 (4AB94365)
fffff880`0106f000 fffff880`010fb000   mv91xx   mv91xx.sys   Wed Jun 30 21:55:14 2010 (4C2BF582)
fffff880`0112a000 fffff880`01132000   mvxxmm   mvxxmm.sys   Wed Jun 30 21:54:57 2010 (4C2BF571)
fffff880`014ed000 fffff880`015df000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0fe3a000 fffff880`0fe46000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0fe46000 fffff880`0fe75000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`07d64000 fffff880`07d79000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d3b000 fffff880`02d4a000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02cc7000 fffff880`02d0c000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01000000 fffff880`01060000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`01225000 fffff880`01236000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`07947000 fffff880`07953000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`03213000 fffff800`037f0000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`0123b000 fffff880`013de000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`019f6000 fffff880`019ff000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`07d4b000 fffff880`07d64000   nusb3hub nusb3hub.sys Thu Dec 09 23:50:35 2010 (4D01B19B)
fffff880`10ba0000 fffff880`10bd1000   nusb3xhc nusb3xhc.sys Thu Dec 09 23:50:35 2010 (4D01B19B)
fffff880`10b38000 fffff880`10b39180   nvBridge nvBridge.kmd Fri Jan 07 20:57:22 2011 (4D27C482)
fffff880`07db0000 fffff880`07dd9000   nvhda64v nvhda64v.sys Thu Nov 11 18:10:36 2010 (4CDC77EC)
fffff880`0fedd000 fffff880`10b37d00   nvlddmkm nvlddmkm.sys Fri Jan 07 21:07:22 2011 (4D27C6DA)
fffff880`02d15000 fffff880`02d3b000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`10bd1000 fffff880`10bee000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00fc5000 fffff880`00fda000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f85000 fffff880`00fb8000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00d8a000 fffff880`00d91000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fef000 fffff880`00fff000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`014d2000 fffff880`014e3000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`07c00000 fffff880`07c3d000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c58000 fffff880`00c6c000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`0fe16000 fffff880`0fe3a000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0fe75000 fffff880`0fe90000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0fe90000 fffff880`0feb1000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`0feb1000 fffff880`0fecb000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`078f6000 fffff880`07947000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`0fecb000 fffff880`0fed6000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01450000 fffff880`01459000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`015df000 fffff880`015e8000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`015e8000 fffff880`015f1000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01921000 fffff880`0195b000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`10b3a000 fffff880`10ba0000   Rt64win7 Rt64win7.sys Wed Nov 24 22:30:11 2010 (4CEDD843)
fffff880`09206000 fffff880`09495280   RTKVHD64 RTKVHD64.sys Wed Dec 29 22:52:42 2010 (4D1C020A)
fffff880`010fb000 fffff880`0112a000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`03c76000 fffff880`03c82000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02d4a000 fffff880`02d67000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`0191a000 fffff880`01921000   speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffff880`01912000 fffff880`0191a000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`03dfb000 fffff880`03dfc480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`02c30000 fffff880`02c3d000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02c12000 fffff880`02c30000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02dc5000 fffff880`02dd9000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00570000 fffff960`0057a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`07837000 fffff880`0785d000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`078c5000 fffff880`078d7000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`03c74000 fffff880`03c75f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`03c63000 fffff880`03c74000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`07cf1000 fffff880`07d4b000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`03c0d000 fffff880`03c63000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`03c00000 fffff880`03c0d000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00fb8000 fffff880`00fc5000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01432000 fffff880`01440000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01200000 fffff880`01225000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`018b6000 fffff880`018c6000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00fda000 fffff880`00fef000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`018c6000 fffff880`01912000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02daa000 fffff880`02dc5000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01440000 fffff880`01450000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e68000 fffff880`00f0c000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f0c000 fffff880`00f1b000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d0c000 fffff880`02d15000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00080000 fffff960`00390000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`00f72000 fffff880`00f7b000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
Unloaded modules:
fffff880`01800000 fffff880`0180e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0180e000 fffff880`0181a000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0181a000 fffff880`01823000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01823000 fffff880`01836000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`01836000 fffff880`01860000   cdrom.sys
    Checksum:  00000000
    ImageSize:  0002A000
@ cybercore i am really grateful for yer time mate.
but how do i know my part number ..as for the driver it needs the part number.
and
@kemical
how do i post a screenshot in such a way ye did there ?
and
@kemical
As I said after reading your dump please update all drivers rather than just point out specifics I just said update them all. As for part numbers please read my post again concerning SiW...
