Windows 7 SUDDEN shutdown/restard ....Neither BSOD, Nor overheating....... ( Kernel-power 41 ) (63)
theabdoul
Well-Known Member
hello everyone
and thanks for stopping by and reading the post
i got a big problem with the pc which is still 2 month old ( if not less ),
it just suddenly turns off or sometimes restarts with no reason, the pc just makes this sound like it's unplugged, i've red each and every single topic about it and still nothing helps me !
am running a
windows 7 64 bit
6gb ram 1333 2gb each one of them is that with it's own cooling
i7 1156
p-55-ud3
gtx 210
case : cooler master haf 920
ps : cougar 750 wts
1 tb grean hd and 2x laptop 250 HDs connected inside.
the problem is ..no bsod shows up ..just nothing
the pc never heats up ...i use speed fan ..t's always cool
and if ye know the cooler master haf ye know it has got lots of fans and i installed one more from the side
but i don't know what else should i say here
please i need help asap ...this is annoying me ...sometimes it even ends my work while doing something ...just like it's unplugged and all me work is gone ...
if ye need any info i will post it ..just ask for it if ye need it
cheeers in advance
apologies for not replying sooner and thanks for posting the dump. The bsod was actually caused by wininit.exe which is a start up module needed by windows. I'd update your drivers, that means all drivers like chipset, network, graphics, audio and so.. Also check for bios updates relevant to your motherboard. If your unsure on how to proceed then post back and we will be happy to point you in the right direction.
I would also either run a repair on windows itself. Change your boot order so you can boot from the 7 disk and then at the installation page choose 'Repair' instead.
Lastly, just to make sure, download malwarebytes Malwarebytes or use your own anti virus app and run a full scan of your machine.
i will be reporting the problems i have ( cpu-z i mean )
and aye it is still runinng 1320 ...i can't change it ....suggest a website that can help me fix it or at least a guide to how to open it through the bios ?!?!
Memory :
Link Removed due to 404 Error
spd 1 :
spd 3 :
spd 4 :
i hope this one helps ...cause the blue screen happens when i log
when the user starts it hppns then i restart and it's gone
but i don't wanna boot twice everytime i use it
