theabdoul
Well-Known Member
hello everyone
and thanks for stopping by and reading the post
i got a big problem with the pc which is still 2 month old ( if not less ),
it just suddenly turns off or sometimes restarts with no reason, the pc just makes this sound like it's unplugged, i've red each and every single topic about it and still nothing helps me !
am running a
windows 7 64 bit
6gb ram 1333 2gb each one of them is that with it's own cooling
i7 1156
p-55-ud3
gtx 210
case : cooler master haf 920
ps : cougar 750 wts
1 tb grean hd and 2x laptop 250 HDs connected inside.
the problem is ..no bsod shows up ..just nothing
the pc never heats up ...i use speed fan ..t's always cool
and if ye know the cooler master haf ye know it has got lots of fans and i installed one more from the side
but i don't know what else should i say here
please i need help asap ...this is annoying me ...sometimes it even ends my work while doing something ...just like it's unplugged and all me work is gone ...
if ye need any info i will post it ..just ask for it if ye need it
cheeers in advance
apologies for not replying sooner and thanks for posting the dump. The bsod was actually caused by wininit.exe which is a start up module needed by windows. I'd update your drivers, that means all drivers like chipset, network, graphics, audio and so.. Also check for bios updates relevant to your motherboard. If your unsure on how to proceed then post back and we will be happy to point you in the right direction.
I would also either run a repair on windows itself. Change your boot order so you can boot from the 7 disk and then at the installation page choose 'Repair' instead.
Lastly, just to make sure, download malwarebytes Malwarebytes or use your own anti virus app and run a full scan of your machine.
i downloaded the software now and am doing what ye asked of me right now : )
if ye are staying by the pc for 10 more minutes i will post them here or sth : )
cheers again fella
I'd still try malwarebytes as it runs great alongside Security Essentials and would enhance your security perfectly. Also to help me further try this app called SiW (System information for Windows): SIW | System Information for Windows by Gabriel Topala . As you can see in this screenshot it will give you the information regarding your system which you can then supply to me..
Link Removed due to 404 Error
there ye go ...
i supplied what ye pointed at
motherboard
network adapter
sounddevice and something else can't remember it
Hey there,
thank you for the screenshots, they helped a huge amount. Ok, this is the actual web page for your motherboard and associated drivers (windows 7 64bit). Please also check your bios is the latest version too...
P55a-UD3
Oh I forgot to tell you that when reading the dump file I noticed you were using an extremely old version of speedfan..
Please download the latest version here:
Speedfan
well i download the bios and it unrars into some weird files including some .bat files ....none of them are exe
none are even executable in any form.
and bout the speed fan
latest is 4.42 .....it is the one am using
isn't it ? i downloaded it again and it is the latest one : )
if not .....please point me to which one
and also the SATA Thing
how do i update it ?
This is a app for flashing Gigabyte boards and is automated, please follow the instructions carefully.:
@Bios
As for Speedfan, my apologies, I checked again and yes your correct. (it was very late last night lol). As for the SATA did you not find drivers on the update page? I'm pretty sure the drivers have an 'exe' to initiate the install?
UNINSTALL LogMeIn.
1. Uninstall LogMeIn
2. Update Marvell SATA Controller
mv91cons.sys Tue Sep 22 17:36:37 2009
Marvell: Support
theabdoul said:
but how do i know my part number ..as for the driver it needs the part number.
and
Start --> Control Panel --> (System) --> Device manager --> Right click on your Marvell device --> Properties --> ID.
UNINSTALL LogMeIn.
Cybercore is asking you to uninstall Logmein as it is known to cause problems with 64bit windows 7. There is a solution however and if you really need to use this app then see below:
Some hardware may have conflicts with the driver LogMeIn employs to display optimized remote
screen video. You can install LogMeIn without the Display Accelerator, and use
the default screen display, which is just as fast over high-speed connections.
To do so:
  1. Please download the manual install file located at the bottom of this document.
  2. Next,create a folder in the C: drive called LMI. Then open the LogMeIn.zip file and extract it to the LMI folder.
  3. Next, go to Start, then Run, and type cmd and click OK.
  4. To find your system type, Right click on the My Computer icon, and choose properties:
    • If the local operating system is 32-bit, then at the command prompt, type:
      1. cd C:\lmi\x86 (hit enter)
      2. logmein install -nomirrordrv (hit enter)
    • If the local operating system is 64-bit, then at the command prompt, type:
      1. cd C:\lmi\x64 (hit enter)
  5. You will then receive a message that the install was successful. Close the
    command prompt window and click "Open LogMeIn" on the message
    that appears, and follow the steps to assign the computer to your LogMeIn
    account.
Related Link:
LogMeIn manual installation file
LogMeIn is also quite notorious for BSOD's, especially that its driver is so old:
[B]lmimirr.sys  Tue Apr 10 18:32:45 2007[/B]
well
1- this bios thing .....no there isn't any exe file with it xD
try downloading it and then see if there is any
2 - the marvell driver ...says it's the best version installed and i couldn't get the ID .....i clicked prop. then in another tab i choose hardware IDs ....found about 3 or 4 there xD
3 - i un-installed log me in xD
4 - i did these bios instructions ye told me about, but when installing it, found out it was ardy there ...ye know ...the installes was asking if i wanna repair it or un-install or so on.
5 - i just had the blue screen again today while booting!! ...but this time was nothing but only 1 line ....saying ...the process was not executed properly and reboot req or so ....but nothing about dump or w/e
( excuse my english fellas ...i just got used on typing this way )
and another bluescreen of doom.
this time it's diff.
this time it is exactly after logging into the user account, it happened
and i restarted
and after restarting ...the "starting windows" sign was there ...it lasted about 10 min. ...so i restarted one more time
and as usual asked for a ( system repair recommended ) thing
so i hit it
and wait for it, then restore ..so i clicked yes
then i had this message :
startrep.exe - application error
the instruction at 0xfc12584d referenced ......well i was copying the error message live from it as soon as it occurred and couldn't complete it cause suddenly another bluescreen comes in!!! don't know how did that happen
and this time this one says
if you bla bla bla
ye know ...first time reading this ....bla bla
and if not ..just disable any newly installed hardware.
does this mean something is wrong with the ram i just installed ( as i said ..i just installed a new 2 gb ddr3 ram ) ?
note: problems were even before i installed it ....but bluescreens started showing after installed it.
i am really annoyed ....there has got to be something to fix all this
i will re-boot now and launch up the start up repair while am writing this reply so everything is live! xD
if it goes on well then i will just post the dump
if it doesn't go well i will just copy what just happened again .....
ok, start up repair launched ....
then clicked repair ....
then clicked restore .....again that's the second time now!
....attempting repairs
....ok it is completed successfully ....
system restarted now.
i notice there is no beep at the motherboard's picture ...before the operating system starts ..there was suppose to be a beep ...didn't happen now
....ok booting process is complete.
i will now log in.
logged in now .......
everything seems to be fine
i will wait exactly 5 more minutes if nothing happened i will submit this reply if anything happened i will continue to post it .....
( waiting... )
ok 5 minutes have passed.
it is fine
nothing more happened
if anything happens i will make sure to post it again for ye.
and i will post the dump in a reply after this one ....
ok there is the dump that just happened ...and while i was there
i found the dump just before it ( the day before it )
so i zipped it as well
hope this helps.
there ye go.
cheers for yer time lads : )
021811-24273-01.dmp
BugCheck 50, {fffffa8604b531db, 0, fffff800032da53b, 5}
Probably caused by : memory_corruption ( nt!MiAgeWorkingSet+41b )
022111-24476-01.dmp
BugCheck F4, {3, fffffa80077d4b30, fffffa80077d4e10, fffff800035842d0}
A process or thread crucial to system operation has unexpectedly exited or been
terminated.
Probably caused by : csrss.exe
1. Start > Accessories > Command Prompt > type chkdsk /f
2. Start > Accessories > Command Prompt > type sfc /scannow
3. Link Removed
4. Run Memtest86+ - Advanced Memory Diagnostic Tool 10 passes overnight
5. Update Realtek NDIS Protocol Driver:
RtNdPt60.sys Sun Jul 19 22:27:32 2009
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\021811-24273-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`03256000 PsLoadedModuleList = 0xfffff800`03493e50
Debug session time: Fri Feb 18 13:07:05.665 2011 (UTC - 5:00)
System Uptime: 0 days 0:03:20.600
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
4: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffffa8604b531db, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff800032da53b, If non-zero, the instruction address which referenced the bad memory
	address.
Arg4: 0000000000000005, (reserved)
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800034fe0e0
 fffffa8604b531db
FAULTING_IP:
fffff800`032da53b 410fb65f1b      movzx   ebx,byte ptr [r15+1Bh]
MM_INTERNAL_CODE:  5
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x50
PROCESS_NAME:  System
CURRENT_IRQL:  0
TRAP_FRAME:  fffff880033e77a0 -- (.trap 0xfffff880033e77a0)
rax=0000058000000000 rbx=0000000000000000 rcx=fffff6fcb0000960
rdx=0000000000000001 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800032da53b rsp=fffff880033e7930 rbp=007ffffcb0000960
 r8=0000000000000001  r9=fffff880089fcc00 r10=0000000000000005
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl zr na po nc
nt!MiAgeWorkingSet+0x41b:
fffff800`032da53b 410fb65f1b      movzx   ebx,byte ptr [r15+1Bh] ds:00000000`0000001b=??
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800033458c1 to fffff800032c6740
STACK_TEXT:
fffff880`033e7638 fffff800`033458c1 : 00000000`00000050 fffffa86`04b531db 00000000`00000000 fffff880`033e77a0 : nt!KeBugCheckEx
fffff880`033e7640 fffff800`032c482e : 00000000`00000000 0bd00201`91bb4001 00000000`00000000 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x40e8b
fffff880`033e77a0 fffff800`032da53b : 00000000`000000c4 00000000`00000001 00000000`00000002 00000000`000000a9 : nt!KiPageFault+0x16e
fffff880`033e7930 fffff800`03348a5e : fffff880`089fcc00 fffff880`00000001 00000000`00000001 fffff880`033e7bb0 : nt!MiAgeWorkingSet+0x41b
fffff880`033e7ae0 fffff800`032daee2 : 00000000`000000c8 00000000`00000000 fffffa80`00000000 00000000`00000002 : nt! ?? ::FNODOBFM::`string'+0x496d6
fffff880`033e7b80 fffff800`032db173 : 00000000`00000008 fffff880`033e7c10 00000000`00000001 fffffa80`00000000 : nt!MmWorkingSetManager+0x6e
fffff880`033e7bd0 fffff800`035697c6 : fffffa80`05213720 00000000`00000080 fffffa80`051f0b30 00000000`00000001 : nt!KeBalanceSetManager+0x1c3
fffff880`033e7d40 fffff800`032a4c26 : fffff880`009b2180 fffffa80`05213720 fffff880`009bd0c0 4800101e`66306804 : nt!PspSystemThreadStartup+0x5a
fffff880`033e7d80 00000000`00000000 : fffff880`033e8000 fffff880`033e2000 fffff880`033e7710 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!MiAgeWorkingSet+41b
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4cc791bd
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0x50_nt!MiAgeWorkingSet+41b
Loading Dump File [F:\a\Minidump\D M P\DMP\022111-24476-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0320b000 PsLoadedModuleList = 0xfffff800`03448e50
Debug session time: Mon Feb 21 02:50:34.286 2011 (UTC - 5:00)
System Uptime: 0 days 0:01:51.332
2: kd> !analyze -v
CRITICAL_OBJECT_TERMINATION (f4)
terminated.
Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa80077d4b30, Terminating object
Arg3: fffffa80077d4e10, Process image file name
Arg4: fffff800035842d0, Explanatory message (ascii)
Debugging Details:
PROCESS_OBJECT: fffffa80077d4b30
IMAGE_NAME:  csrss.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: csrss
FAULTING_MODULE: 0000000000000000
PROCESS_NAME:  csrss.exe
BUGCHECK_STR:  0xF4_C0000005
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`089a0b08 fffff800`03607f62 : 00000000`000000f4 00000000`00000003 fffffa80`077d4b30 fffffa80`077d4e10 : nt!KeBugCheckEx
fffff880`089a0b10 fffff800`035afa23 : ffffffff`ffffffff fffffa80`07d84360 fffffa80`077d4b30 fffffa80`077d4b30 : nt!PspCatchCriticalBreak+0x92
fffff880`089a0b50 fffff800`0353790c : ffffffff`ffffffff 00000000`00000001 fffffa80`077d4b30 000007fe`00000008 : nt! ?? ::NNGAKEGL::`string'+0x17666
fffff880`089a0ba0 fffff800`0327a993 : fffffa80`077d4b30 fffff880`c0000005 ffffffff`ee1e5d00 fffffa80`07d84360 : nt!NtTerminateProcess+0x20c
fffff880`089a0c20 00000000`77c6f97a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0060e0c8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77c6f97a
STACK_COMMAND:  kb
FAILURE_BUCKET_ID:  X64_0xF4_C0000005_IMAGE_csrss.exe
Drivers:
fffff880`00f91000 fffff880`00fe8000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02cf2000 fffff880`02d7c000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0fe00000 fffff880`0fe16000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`010d5000 fffff880`010e0000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`07933000 fffff880`0793b000   AppleCharger AppleCharger.sys Mon Apr 26 23:54:05 2010 (4BD65FDD)
fffff880`00c90000 fffff880`00c99000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00dc8000 fffff880`00df2000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`0183a000 fffff880`01841000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`07922000 fffff880`07933000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`040cc000 fffff880`040ea000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006a0000 fffff960`006c7000   cdd      cdd.dll      Wed Jan 26 01:31:34 2011 (4D3FBFC6)
fffff880`07d4b000 fffff880`07d75000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00e1e000 fffff880`00ede000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01955000 fffff880`01985000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d0d000 fffff880`00d6b000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01418000 fffff880`0148b000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`03deb000 fffff880`03dfb000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`095d0000 fffff880`095de000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`07881000 fffff880`07904000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`07904000 fffff880`07922000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`07872000 fffff880`07881000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0193f000 fffff880`01955000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0959c000 fffff880`095be000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`02c1d000 fffff880`02c60000   dtsoftbus01 dtsoftbus01.sys Wed Dec 22 05:19:28 2010 (4D11D0B0)
fffff880`095ea000 fffff880`095f3000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`095de000 fffff880`095ea000   dump_ataport dump_ataport.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`09200000 fffff880`09213000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`095c4000 fffff880`095d0000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`03ca5000 fffff880`03d99000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`03d99000 fffff880`03ddf000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`0112c000 fffff880`01140000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010e0000 fffff880`0112c000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0149c000 fffff880`014a6000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01905000 fffff880`0193f000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0119e000 fffff880`011e8000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`099f2000 fffff880`099fb000   gdrv     gdrv.sys     Thu Mar 12 23:22:29 2009 (49B9D175)
fffff880`07d75000 fffff880`07d82000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`037e8000 fffff800`03831000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`03c00000 fffff880`03c24000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0922f000 fffff880`09248000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`09248000 fffff880`09250080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`09221000 fffff880`0922f000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`04004000 fffff880`040cc000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`018fc000 fffff880`01905000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`00e0d000 fffff880`00e15000   intelide intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`07961000 fffff880`07977000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0fecb000 fffff880`0feda000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`09251000 fffff880`0925f000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bb0000 fffff800`00bba000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`07986000 fffff880`079c9000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013da000 fffff880`013f4000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01200000 fffff880`0122b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`095be000 fffff880`095c3200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`07da8000 fffff880`07dbd000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0927c000 fffff880`0929f000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00cb5000 fffff880`00cf9000   mcupdate mcupdate.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`09213000 fffff880`09221000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`07977000 fffff880`07986000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`092c0000 fffff880`092cd000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00c76000 fffff880`00c90000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`01800000 fffff880`01831000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`040ea000 fffff880`04102000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`04102000 fffff880`0412f000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`0412f000 fffff880`0417d000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0417d000 fffff880`041a0000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`011e8000 fffff880`011f3000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00ff1000 fffff880`00ffb000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01140000 fffff880`0119e000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`07867000 fffff880`07872000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`018ea000 fffff880`018fc000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`00c6c000 fffff880`00c76000   mv91cons mv91cons.sys Tue Sep 22 17:36:37 2009 (4AB94365)
fffff880`01012000 fffff880`0109e000   mv91xx   mv91xx.sys   Wed Jun 30 21:55:14 2010 (4C2BF582)
fffff880`010cd000 fffff880`010d5000   mvxxmm   mvxxmm.sys   Wed Jun 30 21:54:57 2010 (4C2BF571)
fffff880`014a6000 fffff880`01598000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0fe3a000 fffff880`0fe46000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0fe46000 fffff880`0fe75000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`07d36000 fffff880`07d4b000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02df0000 fffff880`02dff000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d7c000 fffff880`02dc1000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01598000 fffff880`015f8000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`01000000 fffff880`01011000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0785b000 fffff880`07867000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0320b000 fffff800`037e8000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`01237000 fffff880`013da000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01831000 fffff880`0183a000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`07d1d000 fffff880`07d36000   nusb3hub nusb3hub.sys Thu Dec 09 23:50:35 2010 (4D01B19B)
fffff880`10ba8000 fffff880`10bd9000   nusb3xhc nusb3xhc.sys Thu Dec 09 23:50:35 2010 (4D01B19B)
fffff880`10b40000 fffff880`10b41180   nvBridge nvBridge.kmd Fri Jan 07 20:57:22 2011 (4D27C482)
fffff880`0fee5000 fffff880`10b3fd00   nvlddmkm nvlddmkm.sys Fri Jan 07 21:07:22 2011 (4D27C6DA)
fffff880`02dca000 fffff880`02df0000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`10bd9000 fffff880`10bf6000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00d9e000 fffff880`00db3000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d6b000 fffff880`00d9e000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e15000 fffff880`00e1c000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00c5c000 fffff880`00c6c000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0148b000 fffff880`0149c000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`07c00000 fffff880`07ca6000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0955f000 fffff880`0959c000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cf9000 fffff880`00d0d000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`0fe16000 fffff880`0fe3a000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0fe75000 fffff880`0fe90000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0fe90000 fffff880`0feb1000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`0feb1000 fffff880`0fecb000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`0780a000 fffff880`0785b000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`03c9a000 fffff880`03ca5000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`019f0000 fffff880`019f9000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0122b000 fffff880`01234000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`013f4000 fffff880`013fd000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`018b0000 fffff880`018ea000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`07dbd000 fffff880`07dd5000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`10b42000 fffff880`10ba8000   Rt64win7 Rt64win7.sys Wed Nov 24 22:30:11 2010 (4CEDD843)
fffff880`092cf000 fffff880`0955e280   RTKVHD64 RTKVHD64.sys Wed Dec 29 22:52:42 2010 (4D1C020A)
fffff880`095f3000 fffff880`095ff000   RtNdPt60 RtNdPt60.sys Sun Jul 19 22:27:32 2009 (4A63D614)
fffff880`07d82000 fffff880`07da8000   RzSynapse RzSynapse.sys Wed Dec 15 05:32:19 2010 (4D089933)
fffff880`0109e000 fffff880`010cd000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`041a0000 fffff880`041ab000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`03ddf000 fffff880`03deb000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02c00000 fffff880`02c1d000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`018a9000 fffff880`018b0000   speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffff880`018a1000 fffff880`018a9000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0995c000 fffff880`099f2000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`098f5000 fffff880`0995c000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`041ab000 fffff880`041d8000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`03dfb000 fffff880`03dfc480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01603000 fffff880`01800000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`041d8000 fffff880`041ea000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02ce5000 fffff880`02cf2000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02cc7000 fffff880`02ce5000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02c7b000 fffff880`02c8f000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004c0000 fffff960`004ca000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0793b000 fffff880`07961000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`079c9000 fffff880`079db000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0925f000 fffff880`0927c000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`03c98000 fffff880`03c99f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`03c87000 fffff880`03c98000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`07cc3000 fffff880`07d1d000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`03c31000 fffff880`03c87000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`03c24000 fffff880`03c31000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00e00000 fffff880`00e0d000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01841000 fffff880`0184f000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`019bb000 fffff880`019e0000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`01400000 fffff880`01410000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00db3000 fffff880`00dc8000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01855000 fffff880`018a1000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02c60000 fffff880`02c7b000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`019e0000 fffff880`019f0000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ede000 fffff880`00f82000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f82000 fffff880`00f91000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02dc1000 fffff880`02dca000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000f0000 fffff960`00400000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`00fe8000 fffff880`00ff1000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`0929f000 fffff880`092c0000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`01985000 fffff880`01993000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01993000 fffff880`0199f000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0199f000 fffff880`019a8000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`019a8000 fffff880`019bb000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`019bb000 fffff880`019e5000   cdrom.sys
    Checksum:  00000000
    ImageSize:  0002A000
disk checking will be done next time i restart
and about the /scan now
i waited for it ..and it's done and it says something like ..nothing is wrong.
and about the Memtest86+ i didn't know how to do it
and does have anything to do with that it's 86 or 64 ?
the memory screenshot :
the SPD slot 1 screenshot :
the SPD slot 2 screenshot :
the SPD slot 4 screenshot :
the RAMMon screenshot :
and i know this might be silly or sth.
but i didn't know what to download from this update page xD i don't know the name of the product xD
RAM is the problem:
-- 1 Super Talent stick with 2 uknowns
-- currently clocked 1320Mhz while it should be 1333Mhz.
1333 9-9-9-24 1.5v
BIOS setup, DRAM options.
No, nothing to do with bits.
Tutorial: How to use Memtest - TechSpot
so which super talent one
i got 2 super talent.
2 gb each ....
but this means that was the reason why the computer used to turn off suddnly ?
and is there anything i can do fix this 1320 to 1333 ?
and
about the memtest86+
i will do it as soon as i can and post it
but please ...i wanna know : )
is the ram the issue ?!
and are ye sure it is one of the supertalent ? and how do i know which one ...
cheers for yer time
@Abdoula, the sticks are not quite matching, and your RAM frequency is set wrong,
me said:
-- 2 Super Talent sticks with 1 uknown
1333 9-9-9-24 1.5v
---------> BIOS setup, DRAM options.
1333 9-9-9-24 1.5v
You got STT in Slots #1 and #3, UNKNOWN in Slot#4.
If it still crashes after you have set the RAM frequency 1333, try the system with only 1 stick in, remove the others for now. Then if it goes smooth, install EITHER 2 STT sticks OR 1 UNKNOWN instead.
1 - how do i set the ram freq to 1333 ?
and how come the sticks are not matching ? aren't they all 1333 ?
Yes, they are all 1333, but different brands do not always work well together.
I have posted it twice already,
me said:
1333 9-9-9-24 1.5v
You can read about it in your motherboard manual.
and another one
the pc hvn't had anything since the last post
so this is the first one
and i removed one of the rams btw. one of the supertalent ... i couldn't open the bios to fix it ..still don't know how to do so ...and google'd everything..but still everyone talks about his own bios ..
please help me
and thanks
1. CPU-Z memory and RamMon report again, so I can see as you have it now:
2. If the RAM is bugging out, then sorting drivers and software won't help at all. You could try to update to their latest versions:
Realtek Audio RTKVHD64.sys Wed Dec 29 22:52:42 2010
Realtek LAN Rt64win7.sys Wed Nov 24 22:30:11 2010
NEC USB 3.0 nusb3hub.sys Thu Dec 09 23:50:35 2010
Marvell mv91cons.sys Tue Sep 22 17:36:37 2009
However, if the RAM is still running 1320Mhz, you will still be having crashes.
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\022711-21387-01.dmp]
Machine Name:
Kernel base = 0xfffff800`03253000 PsLoadedModuleList = 0xfffff800`03490e50
Debug session time: Sun Feb 27 00:31:07.605 2011 (UTC - 5:00)
System Uptime: 0 days 0:00:23.651
BugCheck 50, {fffff94001200a08, 8, fffff94001200a08, 5}
Probably caused by : win32k.sys ( win32k!NtUserCallHwndLock+b9 )
0: kd> !analyze -v
Arguments:
Arg1: fffff94001200a08, memory referenced.
Arg2: 0000000000000008, value 0 = read operation, 1 = write operation.
Arg3: fffff94001200a08, If non-zero, the instruction address which referenced the bad memory
	address.
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800034fb0e0
 fffff94001200a08
FAULTING_IP:
+3566323236306466
fffff940`01200a08 ??              ???
MM_INTERNAL_CODE:  5
BUGCHECK_STR:  0x50
PROCESS_NAME:  LogonUI.exe
CURRENT_IRQL:  0
TRAP_FRAME:  fffff880026800f0 -- (.trap 0xfffff880026800f0)
rax=0000000000000002 rbx=0000000000000000 rcx=fffff900c2702650
rdx=fffff96000307d00 rsi=0000000000000000 rdi=0000000000000000
rip=fffff94001200a08 rsp=fffff88002680288 rbp=fffff88002680360
 r8=fffff900c0100010  r9=0000000000000000 r10=fffff96000139f80
r11=fffff900c2702650 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz ac pe cy
LAST_CONTROL_TRANSFER:  from fffff800033428c1 to fffff800032c3740
STACK_TEXT:
fffff880`0267ff88 fffff800`033428c1 : 00000000`00000050 fffff940`01200a08 00000000`00000008 fffff880`026800f0 : nt!KeBugCheckEx
fffff880`0267ff90 fffff800`032c182e : 00000000`00000008 00000000`00000000 00000000`00000000 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x40e8b
fffff880`026800f0 fffff940`01200a08 : fffff960`0013a039 00000000`00000000 00000000`0001001a 00000000`00000010 : nt!KiPageFault+0x16e
fffff880`02680288 fffff960`0013a039 : 00000000`00000000 00000000`0001001a 00000000`00000010 fffff960`00139f80 : 0xfffff940`01200a08
fffff880`02680290 fffff800`032c2993 : fffffa80`0828fb60 00000000`00000000 00000000`01049680 00000000`00000020 : win32k!NtUserCallHwndLock+0xb9
fffff880`026802e0 00000000`776165aa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0024eb98 fffff800`032bb080 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x776165aa
fffff880`026806c0 0000007f`fffffff8 : fffff880`02680840 fffff960`0019e5bc fffff800`032df5be 00000000`00000000 : nt!KiCallUserMode
fffff880`026806c8 fffff880`02680840 : fffff960`0019e5bc fffff800`032df5be 00000000`00000000 fffff880`026810b0 : 0x7f`fffffff8
fffff880`026806d0 fffff960`0019e5bb : fffff800`032df5be 00000000`00000000 fffff880`026810b0 00000000`00000000 : 0xfffff880`02680840
fffff880`026806d8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : win32k!AssociateInputContextEx+0x1cb
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff960`0013a039 488bd8          mov     rbx,rax
SYMBOL_STACK_INDEX:  4
SYMBOL_NAME:  win32k!NtUserCallHwndLock+b9
MODULE_NAME: win32k
IMAGE_NAME:  win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4d23ecb0
FAILURE_BUCKET_ID:  X64_0x50_win32k!NtUserCallHwndLock+b9
Drivers:
fffff880`00d71000 fffff880`00dc8000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`052cc000 fffff880`05356000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`081e5000 fffff880`081fb000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`011a9000 fffff880`011b4000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`0813b000 fffff880`08143000   AppleCharger AppleCharger.sys Mon Apr 26 23:54:05 2010 (4BD65FDD)
fffff880`0148b000 fffff880`01492000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`0812a000 fffff880`0813b000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff960`007c0000 fffff960`007e7000   cdd      cdd.dll      Wed Jan 26 01:31:34 2011 (4D3FBFC6)
fffff880`0825a000 fffff880`08284000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00eea000 fffff880`00faa000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`019aa000 fffff880`019da000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d13000 fffff880`00d71000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01072000 fffff880`010e5000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`081d5000 fffff880`081e5000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0a100000 fffff880`0a10e000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`08089000 fffff880`0810c000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`0810c000 fffff880`0812a000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`045b6000 fffff880`045c5000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01994000 fffff880`019aa000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`082ad000 fffff880`082cf000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`05200000 fffff880`05243000   dtsoftbus01 dtsoftbus01.sys Wed Dec 22 05:19:28 2010 (4D11D0B0)
fffff880`0a11a000 fffff880`0a123000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0a10e000 fffff880`0a11a000   dump_ataport dump_ataport.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0a123000 fffff880`0a136000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0a136000 fffff880`0a142000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`10a87000 fffff880`10b7b000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`10b7b000 fffff880`10bc1000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`01000000 fffff880`01014000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`011b4000 fffff880`01200000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0195a000 fffff880`01994000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01850000 fffff880`0189a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`08415000 fffff880`08422000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`0320a000 fffff800`03253000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`10bc1000 fffff880`10be5000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0a16d000 fffff880`0a186000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`0a186000 fffff880`0a18e080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0a15f000 fffff880`0a16d000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`01951000 fffff880`0195a000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`00edb000 fffff880`00ee3000   intelide intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`08169000 fffff880`0817f000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`089be000 fffff880`089cd000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0a18f000 fffff880`0a19d000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bbd000 fffff800`00bc7000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`08365000 fffff880`083a8000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013e0000 fffff880`013fa000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`08422000 fffff880`08427200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`08433000 fffff880`08436d80   LGBusEnum LGBusEnum.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
fffff880`09e00000 fffff880`09e23000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00cbb000 fffff880`00cff000   mcupdate mcupdate.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`0a19d000 fffff880`0a1ab000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`089cd000 fffff880`089dc000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0a1ab000 fffff880`0a1b8000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`01813000 fffff880`01844000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`015e4000 fffff880`015ef000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00ebc000 fffff880`00ec6000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01014000 fffff880`01072000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`045ab000 fffff880`045b6000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`0193f000 fffff880`01951000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`010e6000 fffff880`01172000   mv91xx   mv91xx.sys   Wed Jun 30 21:55:14 2010 (4C2BF582)
fffff880`011a1000 fffff880`011a9000   mvxxmm   mvxxmm.sys   Wed Jun 30 21:54:57 2010 (4C2BF571)
fffff880`014c7000 fffff880`015b9000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`10bf2000 fffff880`10bfe000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`082e0000 fffff880`0830f000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`08400000 fffff880`08415000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`053ca000 fffff880`053d9000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`05356000 fffff880`0539b000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`08451000 fffff880`089b3000   nlndis   nlndis.sys   Fri Aug 27 07:21:17 2010 (4C779FAD)
fffff880`0402f000 fffff880`0459f000   nltdi    nltdi.sys    Fri Aug 27 07:21:18 2010 (4C779FAE)
fffff880`015ef000 fffff880`01600000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0459f000 fffff880`045ab000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`03253000 fffff800`03830000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`0123d000 fffff880`013e0000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01844000 fffff880`0184d000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`089dc000 fffff880`089f5000   nusb3hub nusb3hub.sys Thu Dec 09 23:50:35 2010 (4D01B19B)
fffff880`045c5000 fffff880`045f6000   nusb3xhc nusb3xhc.sys Thu Dec 09 23:50:35 2010 (4D01B19B)
fffff880`10a85000 fffff880`10a86180   nvBridge nvBridge.kmd Fri Jan 07 20:57:22 2011 (4D27C482)
fffff880`08284000 fffff880`082ad000   nvhda64v nvhda64v.sys Thu Nov 11 18:10:36 2010 (4CDC77EC)
fffff880`0fe2a000 fffff880`10a84d00   nvlddmkm nvlddmkm.sys Fri Jan 07 21:07:22 2011 (4D27C6DA)
fffff880`053a4000 fffff880`053ca000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`08066000 fffff880`08083000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00fea000 fffff880`00fff000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00faa000 fffff880`00fdd000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00ee3000 fffff880`00eea000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`083a8000 fffff880`083e5000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cff000 fffff880`00d13000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04000000 fffff880`04024000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0830f000 fffff880`0832a000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0832a000 fffff880`0834b000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`0834b000 fffff880`08365000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`05272000 fffff880`052c3000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`089b3000 fffff880`089be000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`015c9000 fffff880`015d2000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`015d2000 fffff880`015db000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`015db000 fffff880`015e4000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01905000 fffff880`0193f000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`08000000 fffff880`08066000   Rt64win7 Rt64win7.sys Wed Nov 24 22:30:11 2010 (4CEDD843)
fffff880`09e70000 fffff880`0a0ff280   RTKVHD64 RTKVHD64.sys Wed Dec 29 22:52:42 2010 (4D1C020A)
fffff880`0a1b8000 fffff880`0a1de000   RzSynapse RzSynapse.sys Wed Dec 15 05:32:19 2010 (4D089933)
fffff880`01172000 fffff880`011a1000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`0fe13000 fffff880`0fe1f000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`053d9000 fffff880`053f6000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`018fe000 fffff880`01905000   speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffff880`018f6000 fffff880`018fe000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`08431000 fffff880`08432480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01602000 fffff880`017ff000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`00df2000 fffff880`00dff000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`0121b000 fffff880`01239000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`0525e000 fffff880`05272000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`005c0000 fffff960`005ca000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`08143000 fffff880`08169000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`08437000 fffff880`08449000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0a142000 fffff880`0a15f000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`0fe11000 fffff880`0fe12f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`0fe00000 fffff880`0fe11000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`08200000 fffff880`0825a000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`0817f000 fffff880`081d5000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`10be5000 fffff880`10bf2000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00fdd000 fffff880`00fea000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01492000 fffff880`014a0000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`014a0000 fffff880`014c5000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`0189a000 fffff880`018aa000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00ec6000 fffff880`00edb000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`018aa000 fffff880`018f6000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`05243000 fffff880`0525e000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`015b9000 fffff880`015c9000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e00000 fffff880`00ea4000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ea4000 fffff880`00eb3000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0539b000 fffff880`053a4000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`00370000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`00eb3000 fffff880`00ebc000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`09e23000 fffff880`09e44000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`019da000 fffff880`019e8000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`019e8000 fffff880`019f4000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`019f4000 fffff880`019fd000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01800000 fffff880`01813000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`08400000 fffff880`08431000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
    Checksum:  00000000
    ImageSize:  00031000
fffff880`01813000 fffff880`0183d000   cdrom.sys
    Checksum:  00000000
    ImageSize:  0002A000
