Microsoft is developing a Teams Town hall change that will let organizers keep attendee invitations separate from invitations sent to the event crew. The feature is tracked as Microsoft 365 Roadmap ID 476488 and is currently listed for general availability in September 2026.
According to Microsoft’s roadmap entry, the backend change is intended to separate attendee invites from those used by the people running the event. That should give Town hall organizers a cleaner way to manage large audiences without mixing presenters, producers, and other operational staff into the same invitation flow.
The roadmap description is light on implementation detail, but the intended outcome is straightforward: organizers will be able to maintain distinct attendee invitations for a Town hall while retaining separate coordination for the events crew.
This matters most for communications teams and IT departments running company-wide broadcasts, executive briefings, training sessions, or external-facing Town halls. Event crew members often need different calendar visibility, responsibilities, and pre-event coordination than general attendees. Separating the invite lists should reduce manual cleanup and lower the chance that a broad attendee update reaches event operators—or vice versa.
Microsoft lists the feature for Teams on Windows desktop and Mac. It is planned for both Targeted Release and General Availability rings, with availability in Microsoft’s worldwide multi-tenant cloud as well as GCC and GCC High.
Teams administrators should nevertheless flag the change for people who own live-event processes, particularly if those teams currently use shared distribution lists, manually maintained calendars, or separate meetings to keep the production crew apart from attendees. Those workarounds may need adjustment once the new invitation behavior arrives.
Organizers should also avoid assuming that September means universal availability on the first day of the month. Microsoft’s stated release timing is an estimate, and the rollout may appear first for Targeted Release tenants before reaching broader production environments.
The feature is currently scheduled to begin rolling out to eligible Teams tenants in September 2026.
What changes
The roadmap description is light on implementation detail, but the intended outcome is straightforward: organizers will be able to maintain distinct attendee invitations for a Town hall while retaining separate coordination for the events crew.This matters most for communications teams and IT departments running company-wide broadcasts, executive briefings, training sessions, or external-facing Town halls. Event crew members often need different calendar visibility, responsibilities, and pre-event coordination than general attendees. Separating the invite lists should reduce manual cleanup and lower the chance that a broad attendee update reaches event operators—or vice versa.
What admins and organizers should do
There is nothing to enable yet: the feature remains in development, and Microsoft notes that roadmap dates and descriptions can change before release.Teams administrators should nevertheless flag the change for people who own live-event processes, particularly if those teams currently use shared distribution lists, manually maintained calendars, or separate meetings to keep the production crew apart from attendees. Those workarounds may need adjustment once the new invitation behavior arrives.
Published: 2026-07-16T23:08:19.0663227Z
Loading…
www.microsoft.com
