Windows 11 Tweaks to improve and Issues to be fixed ( DEV INSIDER CHANNEL - WIN 11 ( BUILD- 22000.65 CO_RELEASE )
Xcelsior19
1. MOST TABS AND MOUSE SCROLLS ARE JERKY. HOVERING OVER HIDDEN TASKBAR TAKES TIME TO SHOW SOMETIMES. MAKE IT FLUID. SETTINGS PANE TAKE TIME TO LOAD, WIN 10 WAS FASTER.
2. REMOVE SEARCH BAR IN START LOGO DIALOG BOX, THERE IS ONE IN SEARCH BOX ITSELF.
3. WHEN YOU TOGGLE OFF SUGGESTIONS IN START, PLEASE MAKE THAT SPACE OCCUPY WITH THE APPS PINED ABOVE. IT DOESN'T LOOK GOOD HALF EMPTY BOX.
4. WIDGETS ARE SLOW, AGAIN JERKY.
5. MAKE THE WRITE CLICK DIALOG BOX ON DESKTOP SMALLER (COMPACT), ON SMALLER DISPLAYS IT LOOKS ABNORMAL AS PER THE SCALE OF RESOLUTION. (AND YES MY GRAPHIC CARD IS COMPATIBLE AND CAPABLE! ).
6. ADD SNIP TOOL EXTENSION IN RIGHT CORNER OF TASKBAR. IT IS ANNOYING TO OPEN THE APP AGAIN N AGAIN TO TAKE A SCREENSNIP.
7. YOU COULD HAVE MADE ROUNDER TASKBAR APPS PINNED.
8. ALL DIALOG BOXES ARE HAVING ROUND EDGE, BUT WHY THE OLD TAB VIEW IN RIBBON SECTION IN FOR EG. WINDOWS EXPLORER. MAKE THE TABS ROUNDER TOO, FROM POINTIER.
9. PLEASE ALLOW APPS LIKE XBOX BE UNINSTALLED.
Wynona
Please don't type in all caps. It's hard on the eyes and not easy to read.
