Axelgrinder
- Joined
- Dec 9, 2011
- Messages
- 4
- Thread Author
- #1
Hey guys!
Ill try to make this as short and as sweet as i can for everyone. I recently just installed w7 32bit from XP, by using the upgrade version of w7, but im trying to make it so i can run w7 64bit version, so I purchased an OEM w7 64bit. My question is, is this even possible to do? Install the OEM w7 64bit over the upgraded 32bit? Ive read that i have to do a clean install, but when i boot from the OEM cd, it says "Windows is loading files..." and then it goes to the windows home screen and then just stops there. Nothing is being loaded, but i can still move my cursor freely. Any suggestions on what i should/could do to get w7 64bit up and running? Any replies would be greatly appreciated. Thanks!
Trouble
Noob Whisperer
- Joined
- Nov 30, 2009
- Messages
- 13,722
That is correct. You cannot upgrade any Windows Operating System from 32 bit to 64 bit (or vice versa) without performing a clean install.Ive read that i have to do a clean install,
I would strongly suggest taking whatever steps possible to secure your critical data (email, music, documents, images, etc.,) either by creating a system image using the built in Windows 7 utility or any of a number of third party imaging software products, to an external medium (USB Hard drive) and test and verify it. At minimum at least a files and folders backup of that data.
Axelgrinder
- Joined
- Dec 9, 2011
- Messages
- 4
- Thread Author
- #3
Thanks for the quick reply. I have everything i needed saved on a flash drive. The problem im having is when i boot up the 64 bit from cd/dvd drive, it hangs right after it says "Windows is loading files..." Even when i boot up the upgrade version of the 32 bit cd it does the same thing. I have no idea where to even begin to troubleshoot this problem. Was curious if anybody has had encountered this problem before. Any suggestions?
Similar threads
- Replies
- 1
- Views
- 2K
- Solved
- Replies
- 2
- Views
- 1K
- Replies
- 4
- Views
- 2K
- Replies
- 1
- Views
- 1K
- Replies
- 4
- Views
- 1K
