Windows 7 Visual Studio Installtion Error
Harjinder
Active Member
When I reinstall Microsoft Visual Studio 2005 following error message displayed and then setup is failed.Kindly help me.
An image from 'Visual Studio Installtion Error'. Visual Studio 2005 setup shows an error 1935 during installation of a specific assembly.
Most probably you have some programs in the background, interfering with the installation. The easiest solution could be to install SmartClose
http://www.snapfiles.com/downloadfind.php?action=s&ref=2&st=smartclose
and run it with defaults, then install Visual Studio. SmartClose shuts down everything but the necessary. I would recommend to shut down Security Programs. After reboot, do start them again, they should do it automatically, but check it.
Further options include typing in Run, and there are lots of variations, if they work... is a question.
Pauli
Fantastic Member
