W7 or ZA Problem-- nag screen??
This problem started a month ago and I still can't seem to come up with a solution.
I have W7 and Zone Alarm. The main engine, zlclient is in my startup folder. When I boot up, I keep getting the typical W7 window: "Do you want to allow the following program make changes..." It is referring to the ZA program. If I say NO, then ZA will not load. So, I say yes. But there is no way to remember this answer for just this program.
I have tried uninstalling and then reinstalling ZA. I have also tried (somewhat) running it in XP compatability mode. I still get the same nag screen when I start my computer. It does not happen with my 3 XP computers.
Any ideas? Any settings to try?
Mel
Joe S
It's probably the Zone Alarm. I quit using it years ago when they bloated it up and it got annoying to work with.
Joe
Joe
They do have a free version with just the basic functionality of a firewall, and not much knowledge is needed to run it, ya know...
Check Point ZoneAlarm
