- Thread Author
- #1
W7 64 bit ... all updates
In last couple of days PC has become unreliable ... after it's been running a while screen freezes, cursor locked ... ctl+alt+del will not work.
When this happens found I can recover ... but often only for 1 or 2 mins ... by simply plugging something into USB port .. as soon as you get the "Bing Bong" device found noise, screen unfreezes.
Sometimes just waiting 30 sec to a min and screen will unfreeze.
Also notice frequently when working, the cursor changes to window resize mode (double ended arrow) and then work is erratic until it recovers.
Also cursor will frequently 'disappear' when you move to an active window, or turn into text entry 'vert bar' cursor for no reason. Both Kyb & Mouse are USB
Sometimes hitting 'ESC' several times will return control temporarily.
I have reinstalled mouse driver .... but no change.
Seems like it is USB related.
Run sfc /scannow it advised corruption on some files and unable to repair.
The CBS log is immense, and I think beyond my abilities to know what needs to be fixed (and how to fix) probably not good enough.
System Restore - went back 8 different restore points - all fail to restore 'unspecified error 0xc0000022' Have had no error reports that restore points had failed.
Is there an option to 'repair' a windows install ? or other suggestions ....
