PeterD
Well-Known Member
Hi Thanks for calling in.
I thought I'd be clever and 'have a go' at installing Android on my Windows Machine 'not a good idea' as half way through the installation it threw its legs up and decided it was not going to install. Now when I boot into Windows 10 I get GRUB and have to EXIT twice before it will boot Windows what can I do to get my boot into Windows sequence 'back to normal' I imagine this involves getting into the Bios. I thought maybe reinstall Windows may correct the problem but NO.
I'm not sure if this Post should have gone onto the Android Forum but as I no longer wish to TRY Android I thought this the perfect Forum to get my Windows machine back to being a Windows Machine with your help, THANKS..
PLEASE wherever you are and whoever you are Stay Safe. P....
Very old Asus M553
1 TB SSD
4Gb
You'll probably need the advanced install mode in the Windows installer and format the drive through there. Windows probably just sees a disk with unknown filesystems that it can't use
Neemobeer
Windows Forum Team
