- Thread Author
- #1
Hello,
I'm having a specific problem with XP Mode. When I change the size of XP Mode window it instantly get me logged off. After I change the size I have to login again in to XP mode. I mean It's a silly problem, couldn't find any solution anywhere, or anything remotely similar, so it might be I'm doing something wrong. These are specs of PC:
System Information
Operating System: Windows 7 Enterprise 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
System Manufacturer: INTELR
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz (2 CPUs), ~700MHz
Memory: 3072MB RAM
Available OS Memory: 3070MB RAM
Page File: 1344MB used, 4794MB available
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
Display Devices
Card name: Radeon X300/X550/X1050 Series (Microsoft Corporation - WDDM)
Manufacturer: ATI Technologies Inc.
Chip type:
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_5B63&SUBSYS_1490174B&REV_00
Display Memory: 1405 MB
Dedicated Memory: 126 MB
Shared Memory: 1279 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor Name: BenQ FP91G+ (Digital)
Monitor Model: BenQ FP91G+
Monitor Id: BNQ76A6
Native Mode: 1280 x 1024(p) (60.020Hz)
Output Type: DVI
Driver Name: atiumdag.dll,atiumdva.cap,atitmmxx
Driver File Version: 8.14.0010.0630 (English)
Driver Version: 8.56.1.15
DDI Version: 9Ex
Driver Model: WDDM 1.0
Driver Attributes: Final Retail
Driver Date/Size: 7/14/2009 02:14:55, 4030976 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71EE2-1823-11CF-8D76-9A34A1C2C535}
Vendor ID: 0x1002
Device ID: 0x5B63
SubSys ID: 0x1490174B
Revision ID: 0x0000
Driver Strong Name: atiilhag.inf:ATI.Mfg.NTx86...1:ati2mtag_RV370:8.56.1.15ci\ven_1002&dev_5b63
Rank Of Driver: 00F42001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
If there's any other info you need just say it. Thanks in advance.
System Information
Memory: 3072MB RAM
Display Devices
Chip type:
Monitor Id: BNQ76A6
Output Type: DVI
DDI Version: 9Ex
WHQL Logo'd: n/a
Vendor ID: 0x1002
Device ID: 0x5B63
Revision ID: 0x0000
D3D Status: Enabled
AGP Status: Enabled
