cybercore
Needless to say XP is a very popular and remarkable operating system. One thing XP has definitely left to be desired is its looks. I think there is nothing wrong if we try to make it look more like 7. So, there are two ways:
1). Automatic by using the 7 Transformation Pack (Link Removed - Invalid URL)
2). Change XP looks manually, fully or partially. A very good tutorial is Link Removed - Invalid URL.
I prefer to modify manually:
1. Link Removed - Invalid URLUxtheme Multi-patcher will allow you to use any 3rd party msstyle theme on Windows XP/SP1/SP2 or Windows Server 2003 (with Themes enabled) just by patching the uxtheme.dll (dynamic link library).
x32 & x64 bit compatible.
2. Go to www. deviantart.com and get a 7-like msstyle theme. Extract it to your C:\WINDOWS\Resources\Themes\ > then double-click on it and apply.
Link Removed due to 404 Error
3. You need Link Removed - Invalid URL if you wish to add 7 icons.
4. Link Removed - Invalid URL
Lee Soft
5. ViStart
(7 Start Menu)
6. Lee-Soft - ViGlance: Windows 7 SuperBar for XP
7. Link Removed due to 404 Error
(7-like explorer)
8. Visual Task Tips - Home
(optional, if you don't use viGlance)
9. TaskSwitchXP - Alt-Tab Replacement For XP - NTWind Software
(awsome software that allows task switching with visual previews)
10. Link Removed - Invalid URL
(this program is great but a little buggy, its development paused)
11. TokyoDownstairs: Magic Formation
(a nice handy launcher that you can also use in Vista and 7)
12. Sidebar:
[AddOn] Windows Sidebar v6.0.6002.18005 - WinCert.net Forums
Drew is quite right, that way or XP > Control Panel > Install/Uninstall programs > see the list of all that's installed in your system.
But if you can't see a TP or anything like that, then someone may have done it manually. :) Ok, post your desktop screenshot, droflex, I'm curious. :)
Aaaaaah. It looks like the guy I bought my computer from must have done this. I was wondering why the "XP" I have didnt look like the "XP" I was use to. It looks like Windows 7 but it's not Windows 7.
I dont have all the super-duper fancy things like the cascading windows so it must be the "7 transformation pack".
Is there a way to find out what was installed to make it look that way?
Thanks for posting this.
Heres the screenshot
This is so awesome. I can't have Win7 on my PC cause it's not powerful enough, but now it looks like it at least, lol.
