Streaky prints in Windows 10 or Windows 11 are best diagnosed by comparing a Windows test page with a page printed directly from the printer, then checking that the paper and print settings match. If the printer’s own page is streaky, inspect the inkjet nozzle pattern and run printhead cleaning if needed, or check the toner cartridge on a laser printer. The Windows paths below apply to both versions; printer maintenance menus vary by manufacturer and model.
Two printers, a computer, toner, and color test sheets are arranged on an office desk. Before you start​
  • Have several sheets of clean, dry plain paper ready. Use paper that your printer’s manufacturer says is suitable for the machine; inkjet and laser photo papers are not necessarily interchangeable.
  • Make sure the printer is on, connected to the PC, and not reporting a paper jam or another error. Keep a sample of the streaky print for comparison.
  • Identify the printer type. An inkjet uses ink cartridges or refillable ink tanks; a laser printer uses toner. The maintenance procedures are different.
  • Find the model name on the printer. You may need its manual or the manufacturer’s Windows utility if a maintenance option is missing.
  • Set aside about 15 minutes for the initial checks. Further cleaning or service can take longer.
Microsoft ended regular support for Windows 10 on October 14, 2025. The printer procedures still apply, but consider the security implications of continuing to use an unsupported Windows installation.
Print a Windows test page​
The Windows test page checks that Windows can send a job to the selected printer and provides a sample to compare with the original document. It does not, by itself, distinguish a Windows setting from a printer hardware problem.
Windows 11​
  1. Open Start > Settings > Bluetooth & devices > Printers & scanners.
  2. Select the printer that produced the streaks.
  3. Select Printer properties.
  4. On the General tab, select Print Test Page.
Windows 10​
  1. Open Start > Settings > Devices > Printers & scanners.
  2. Select the printer, then select Manage.
Keep the page and look for missing sections, faded printing, or lines similar to those on the original document. A Windows test page may not exercise every color or cover enough of the sheet to reveal every defect, so a clean result is useful but not conclusive.
If no page comes out, check the printer display for an error and make sure you selected the intended printer. Open its print queue from Printers & scanners and check whether the job is waiting or the printer is offline. Resolve the connection or queue problem before treating the missing page as a print-quality problem.
Check the paper and print settings​
A mismatch between the loaded paper and the selected media type can affect print quality. For this first test, use plain paper rather than specialty stock.
  1. Remove the paper from the input tray. Load a small stack of clean, dry plain paper supported by the printer, and adjust the paper guides to fit without bending the sheets.
  2. Open the printer’s Printing preferences:
    • Windows 11: Open Start > Settings > Bluetooth & devices > Printers & scanners, select the printer, then select Printing preferences.
    • Windows 10: Open Start > Settings > Devices > Printers & scanners, select the printer, then select Manage > Printing preferences.
  3. Find the paper and quality options. Depending on the driver, they may be under Paper/Quality or a similarly named tab.
  4. Set the paper type to match what is loaded—for this test, choose the plain-paper option. Set the paper size to the actual size in the tray, such as Letter or A4.
  5. Set print quality to Normal or Best, if available. Turn off Draft, Economy, or Toner saver for the test if your driver offers them.
  6. Select Apply, then OK. Print the original document again.
Also check the print dialog in the application you are using. An application’s job-specific paper or quality selections can differ from the defaults you just checked. If the printer asks you to confirm the paper type or size at its own control panel, make that information match the loaded paper as well.
To undo the settings: Return to Printing preferences, select your previous paper, quality, and economy options, and choose Apply. If you use specialty paper later, change the paper type and size to match that stock rather than leaving the plain-paper test settings in place.
Compare with a page printed by the printer​
A printer-generated report or test page is useful because it can be printed without sending the page from a Windows application. Its exact name and menu location depend on the printer.
  1. At the printer’s control panel, look for a test page, print-quality report, or similar diagnostic page. If you cannot find one, consult the manual for the exact model.
  2. Print the page using the same clean plain paper.
  3. Compare it with the Windows test page and the original document.
Use the results to choose the next step:
  • The printer’s own page is streaky: The paper, consumables, or printer hardware are more likely places to investigate. Follow the inkjet or laser section below.
  • The printer’s own page is clean, but the Windows page is streaky: Recheck Windows printing preferences and the selected printer and driver. The comparison points toward the Windows print path, although it does not prove the cause.
  • Both test pages are clean, but one document is streaky: Check that document’s print settings and try another file or application. A small test page may not show a defect that appears in a large image or solid color area.
  • Only copies are streaky: If pages printed from Windows and the printer’s own reports are clean, the issue may be in the scanning path rather than the print engine. Follow the model’s instructions for checking its scanner glass and document feeder.
Inkjet: check the nozzles and clean the printhead​
Use this section only for an inkjet. A nozzle check is more informative for an inkjet than a general Windows test page: it prints a pattern designed to show gaps or missing colors.
Before cleaning: Check that the printer has enough ink and is not showing an error. Cleaning uses ink, and repeated or deep cleaning can use substantially more. Do not remove, rinse, or wipe a printhead unless the instructions for your exact model explicitly tell you to do so.
  1. Load plain paper and leave the printer powered on.
  2. Open the printer manufacturer’s maintenance utility on the PC, or use the printer’s control panel. Look for Nozzle Check, Print Head Nozzle Check, or a similar maintenance option. The utility may be installed separately from the basic Windows printer driver.
  3. Print the nozzle-check pattern. Compare the printed lines and color areas with the good and bad examples in the utility or the printer’s manual.
  4. If the pattern is complete, do not clean the head just because the original page was streaky. Recheck the paper and quality settings. If lines or colors look misaligned, use the model’s Print Head Alignment procedure instead.
  5. If the pattern has gaps, missing lines, or missing color areas and there is enough ink, select the normal Cleaning or Print Head Cleaning option. Follow the prompts and allow the operation to finish.
  6. Print another nozzle-check pattern. Compare it with the first one, then print the original document again if the pattern has improved.
For a concrete example, Canon’s G6000 series Windows utility uses Canon IJ Printer Assistant Tool > Cleaning. The tool asks for an ink group and starts cleaning when you select Start; afterward, it offers Print Check Pattern. Other models and manufacturers use different utilities and controls.
If one normal cleaning does not help, consult your model’s instructions before repeating it. Canon permits a second normal cleaning on the G6000 series, but that sequence is not a universal rule. Avoid repeatedly starting cleaning cycles without checking the pattern.
Do not jump straight to deep cleaning or an ink flush. These consume more ink, and the prerequisites and waiting periods vary by model. If normal cleaning does not improve the pattern, use the exact manufacturer procedure or contact its support service. A persistent missing pattern can also indicate an ink supply or printhead problem that cleaning alone will not solve.
Laser: check the toner cartridge​
A laser printer does not use the inkjet nozzle-cleaning procedure. Faint areas, streaks, or lines can involve the toner cartridge, but paper, the drum, or other internal components can also be responsible.
Before opening the printer: Follow the safety and cartridge-handling instructions for your exact model. Internal parts can be hot. Avoid touching the drum surface or electrical contacts, and do not use liquids or improvised cleaning tools inside the machine.
  1. Check the printer display or its manufacturer’s utility for a low-toner, cartridge, or supply warning. Replace a cartridge if the printer indicates replacement is needed, using the correct cartridge for the model.
  2. If the manual permits you to inspect the cartridge, open the cartridge access cover as instructed and carefully remove it by its handle or designated grip.
  3. Look for obvious damage or toner leakage without touching sensitive surfaces. Do not continue using a visibly damaged or leaking cartridge; follow the manufacturer’s replacement and cleanup directions.
  4. If the cartridge appears intact, reinstall it according to the manual and close the cover completely. On models with a separate drum unit, follow the model’s instructions for the cartridge-and-drum assembly rather than forcing either part.
  5. Print the printer’s diagnostic page again and compare it with the earlier sample.
Some manufacturers recommend gently redistributing toner for particular streak patterns and models. For example, HP documents this for certain LaserJet Pro print-quality problems. Do it only if the instructions for your cartridge permit it; do not assume every cartridge should be shaken.
If streaks remain, check whether the manufacturer provides a cleaning page procedure for the model. This is different from inkjet printhead cleaning. If a replacement cartridge does not help, or if the printer’s own report remains streaky, the printer may need drum, paper-path, or other model-specific service.
Verify the fix and handle remaining problems​
Print the same original document on the same type of paper used for the successful test. For an inkjet, also keep the final nozzle-check pattern; for a laser printer, compare the final diagnostic page with the first one. The useful result is not merely that a page prints, but that the missing areas or streaks have disappeared from the relevant pages.
If the problem remains, use the matching symptom:
  • The printer’s report is clean, but one application still streaks: Check its print dialog for a different paper type, quality setting, or draft mode. Try a different document in that application and the original file from another application.
  • The printer’s report is clean, but several Windows applications streak: Recheck that the correct printer is selected and that its preferences match the paper. Obtain the current driver and maintenance software for the exact model from the manufacturer, then follow its installation instructions.
  • The maintenance or nozzle-check option is missing: Look in the manufacturer’s utility or on the printer itself; not every basic Windows driver exposes maintenance controls. Consult the exact model’s manual before installing additional software.
  • The inkjet pattern is still missing lines after the documented cleaning procedure: Stop repeated cleaning and follow the model’s escalation instructions. Note which colors or sections are missing when contacting support.
  • A laser printer still produces the same lines on its own report: Keep the report, note any supply messages and cartridge changes, and contact the manufacturer or a qualified service provider. The Windows print settings alone are unlikely to fix a defect already present on the printer-generated page.
