The thread discusses a user's recurring BSOD issues during gaming and browsing, with a responder analyzing crash dumps and identifying probable hardware-related causes, including outdated BIOS and drivers. They recommend updating the BIOS, USB, audio, storage, and graphics drivers, and removing possibly conflicting software like RivaTuner. The overall advice centers on updating drivers and hardware diagnostics to resolve the stability problems.
Pavillion
Hi guys,
I keep getting random BSOD when playing games like CS:GO and also at random times just browsing the net/watching movies. Can you please assist
cheers.
BugCheck 3B, {c0000005, fffff80002e8a9df, fffff8800eb49ff0, 0}
Probably caused by : hardware ( nt!KeWaitForSingleObject+1df )
Followup: MachineOwner
of the three dmp files you sent 2 were the same (like above) and the other was a Bugcheck 124 which is again pointing to...
of the three dmp files you sent 2 were the same (like above) and the other was a Bugcheck 124 which is again pointing to hardware as the culprit. Even so, a driver, a corrupted or out of date driver can cause these kind of bsods.
BiosVersion = P1.50
BiosReleaseDate = 07/30/2012
Please update Bios: http://www.asrock.com/mb/Intel/X79 Extreme6/?cat=Download&os=BIOS
Please make sure I have the correct page for your motherboard.
asmthub3.sys Fri Mar 04 07:55:10 2011
asmtxhci.sys Fri Mar 04 07:54:59 2011
ASMedia ASM1042 USB3 drivers. Please update:
Link Removed (your driver is the top one on the list but also try and update the firmware too which you'll see the download for is located under the first driver.
AsrAppCharger.sys Tue May 10 09:28:46 2011:
ASRock App Charger Likely BSOD cause un-install to test. (there is a later version on the moBo website)
cfosspeed6.sys Mon Jul 04 14:18:51 2011:
Internet Accelerator update if possible: http://www.cfos.de/en/cfosspeed/support.htm
cmudaxp.sys Thu Mar 10 07:44:15 2011:
This is an audio driver for either (please update):
C-Media Audio Interface Driver (WDM) by C-Media: Link Removed
ASUS Xonar DG Audio Interface driver: Link Removed
HTO CLARO Audio Interface Driver: Link Removed
FNETURPX.SYS Sat Oct 04 03:27:02 2008:
AsRock XFastUSB package please update: http://www.asrock.com/mb/Intel/X79 Extreme6/?cat=Download&os=Win764 ( look under 'Utilities)
iaStorA.sys Wed Oct 12 21:29:51 2011:
Intel RST (Rapid Storage Technology) driver: MoBo website has later version: http://www.asrock.com/mb/Intel/X79 Extreme6/?cat=Download&os=Win764
iaStorF.sys Wed Oct 12 21:28:40 2011:
Intel RST (Rapid Storage Technology) Filter driver: MoBo website has later version: http://www.asrock.com/mb/Intel/X79 Extreme6/?cat=Download&os=Win764
nvlddmkm.sys Wed Oct 23 07:21:50 2013:
Please update to latest driver: http://www.nvidia.com/Download/index.aspx?lang=en-us
Unloaded modules:
fffff880`06c37000 fffff880`06c3d000 RTCore64.sys:
The above 'RTcore64.sys' relates to either: RivaTuner/EVGA Precision/MSI Afterburner (known BSOD issues w/Win7) Please remove to test.
If after updating the above you still see bsod then run Memetest86 and post results:
http://www.memtest.org/
