scruffy1
Well-Known Member
hi
i'm new to the forum, and seeking some assistance that other sources have failed to provide thus far - i'm far from a noob, and a keen overclocker, but only had win 7 up for several months, and this is a relatively recent issue without any new hardware changes, or setting adjustments
apart from the cpu (when the multi kicks up to 9 anyway), the rest of my rig runs at stock speed, although i have recently also overclocked the gpu for gaming, under good cooling and without any issue when playing - the cpu is under a thermalright ultra extreme, and the xfx has a thermalright v2 as demonstrated Link Removed
the weird part is that it only seems to have gone bad with embedded video, almost without doubt i can provoke a bluescreen by viewing Link Removed content, but gaming isn't even an issue
i had troubles in upgrading catalyst (that's hardly unique) and it seemed to be a problem using ati tool or the msi equivalent; oddly now though catalyst control centre seemed well behaved, and i can manually overclock the xfx in gaming to 920/1400 (and 60% manual fan) without problems, i note after the last bsod to gain a minidump and ran your tools that ccc has set the default speeds to 400/900 instead of the previous 157/300 or so :curious: fixed with a reboot
what's that all about ? :shocked:
anyway, i digress..
i would love your thoughts on the situation
the memory memtests fine (10 runs overnight), the gpu does furmark benching without concerns, and it's too hot here to prime the cpu, but i am not too sure that is issue either - 5 cycles of LinX for a down 'n' dirty trial show zero errors
please, please, please make it go away...
many thx in anticipation of useful input
:pray:
  • minidump files.zip
    minidump files.zip
  • Seven Forums.zip
    Seven Forums.zip
Re: ntoskrnl bluescreens - solved at last
last word on the matter - turns out the problem was likely just me wimping out on northbridge and gmch voltage for the amount of ram (4gb) and fsb speeds i push it to go
since adding +0.2v to both, and the requisite +0.3v to the corsair dominators for 1068mhz @ 5-5-5-15, the cpu is good to go at 4ghz reading 1.2v in cpuz under load :l:
:up: take that, ntoskrnl :ahaha:
Elmer
Hi scruffy1 and Welcome.
STOP 0x000000C1: SPECIAL_POOL_DETECTED_MEMORY_CORRUPTION
Usual causes:
Device driver, ?Memory
Need to sort out your drivers first.
ZoneAlarm Security and Firewall is known to be a cause of BSOD's on many Windows 7 systems. Download the ZoneAlarm Remover Link Removed due to 404 Error. Uninstall ZoneAlarm through Programs and Features. Boot to safe mode and run the ZoneAlarm Remover. Reboot. Make sure that Windows Firewall is enabled.
Alternatively
Try this Microsoft hotfix if you wish to keep ZoneAlarm: Stop Error 0x07F when you run applications that transfer data using the UDP protocol in Win Server 2008 R2/Win 7" which I can neither verify or discount. It may work, it may not.
Outdated Drivers. Update:
Afc.sys Wed Jul 12 06:48:20 2006 Arcsoft ASPI Shell (CD/DVD program)
ALSysIO64.sys Sun Apr 19 20:41:04 2009 Core Temp - CPU temperature monitor Update.
Envy24HF.sys Wed Apr 06 11:07:18 2005 Link Removed
Drivers to Update:
Rt64win7.sys Wed Jun 23 10:10:45 2010 Link Removed
There's also an update for your Graphics. Link Removed.
Dump File:
BugCheck C1, {fffff980592285d0, fffff98059228343, ff4a30, 32}
Probably caused by : memory_corruption ( nt!MiCheckSpecialPoolSlop+83 )
Followup: MachineOwner
1: kd> !analyze -v
SPECIAL_POOL_DETECTED_MEMORY_CORRUPTION (c1)
Special pool has detected memory corruption.  Typically the current thread's
stack backtrace will reveal the guilty party.
Arguments:
Arg1: fffff980592285d0, address trying to free
Arg2: fffff98059228343, address where one bit is corrupted
Arg3: 0000000000ff4a30, (reserved)
Arg4: 0000000000000032, caller is freeing an address where nearby bytes within the same page have a single bit error
Debugging Details:
BUGCHECK_STR:  0xC1_32
SPECIAL_POOL_CORRUPTION_TYPE:  32
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP
PROCESS_NAME:  System
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff8000314b5f3 to fffff800030bb740
STACK_TEXT:
fffff880`0312ba98 fffff800`0314b5f3 : 00000000`000000c1 fffff980`592285d0 fffff980`59228343 00000000`00ff4a30 : nt!KeBugCheckEx
fffff880`0312baa0 fffff800`031c2693 : fffff800`00b96080 00000000`00000000 fffff980`592285d0 fffff800`0324a440 : nt!MiCheckSpecialPoolSlop+0x83
fffff880`0312bae0 fffff800`031ee356 : fffff800`0304b000 00000000`73707249 00000000`5d75d2a0 fffff800`0324a440 : nt!MmFreeSpecialPool+0x1d3
fffff880`0312bc10 fffff800`035601f6 : 45454545`45454500 45454545`00000000 45454545`45454500 45454545`45454500 : nt!ExDeferredFreePool+0xf13
fffff880`0312bcc0 fffff800`0335fc06 : fffff980`00418b60 fffff980`00066b30 45454545`45454545 45454545`45454545 : nt!ViPoolDelayFreeTrimThreadRoutine+0x46
fffff880`0312bd00 fffff800`03099c26 : fffff800`03235e80 fffff980`00418b60 fffff800`03243c40 45454545`45454545 : nt!PspSystemThreadStartup+0x5a
fffff880`0312bd40 00000000`00000000 : fffff880`0312c000 fffff880`03126000 fffff880`0312ba10 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`0314b5f3 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!MiCheckSpecialPoolSlop+83
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0xC1_32_VRFK_nt!MiCheckSpecialPoolSlop+83
1: kd> lmsmtn
fffff880`00f0a000 fffff880`00f61000   ACPI     ACPI.sys     Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`04828000 fffff880`04831000   Afc      Afc.sys      Wed Jul 12 06:48:20 2006 (44B48D24)
fffff880`02c0b000 fffff880`02c95000   afd      afd.sys      Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`045cd000 fffff880`045e3000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`04852000 fffff880`04983000   agrsm64  agrsm64.sys  Thu Aug 13 16:20:43 2009 (4A842F4B)
fffff880`08dbb000 fffff880`08dc3000   ALSysIO64 ALSysIO64.sys Sun Apr 19 20:41:04 2009 (49EB7E50)
fffff880`00ff5000 fffff880`01000000   amdxata  amdxata.sys  Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`04df0000 fffff880`04df9000   aswFsBlk aswFsBlk.SYS Tue Sep 07 15:47:09 2010 (4C86506D)
fffff880`04c23000 fffff880`04c5d000   aswMonFlt aswMonFlt.sys Tue Sep 07 15:47:32 2010 (4C865084)
fffff880`02c95000 fffff880`02c9f000   aswRdr   aswRdr.SYS   Tue Sep 07 15:47:47 2010 (4C865093)
fffff880`03ad6000 fffff880`03af9000   aswSP    aswSP.SYS    Tue Sep 07 15:52:07 2010 (4C865197)
fffff880`01850000 fffff880`01860000   aswTdi   aswTdi.SYS   Tue Sep 07 15:52:27 2010 (4C8651AB)
fffff880`08c71000 fffff880`08c7c000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00e1a000 fffff880`00e23000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e23000 fffff880`00e4d000   ataport  ataport.SYS  Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`04cd4000 fffff880`04cf4000   AtihdW76 AtihdW76.sys Wed Nov 17 12:02:04 2010 (4CE3C43C)
fffff880`03c07000 fffff880`043fc000   atikmdag atikmdag.sys Wed Oct 27 03:29:53 2010 (4CC78EA1)
fffff880`03b35000 fffff880`03b80000   atikmpag atikmpag.sys Wed Oct 27 03:14:23 2010 (4CC78AFF)
fffff880`019a0000 fffff880`019a7000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`01000000 fffff880`01011000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`04600000 fffff880`0461e000   bowser   bowser.sys   Tue Jul 14 00:23:50 2009 (4A5BC206)
fffff960`00610000 fffff960`00637000   cdd      cdd.dll      Tue Nov 02 04:59:22 2010 (4CCF9AAA)
fffff880`0196d000 fffff880`01997000   cdrom    cdrom.sys    Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00cd6000 fffff880`00d96000   CI       CI.dll       Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`01907000 fffff880`01937000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00c78000 fffff880`00cd6000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`010e8000 fffff880`0115b000   cng      cng.sys      Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`0483e000 fffff880`0484e000   CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`08556000 fffff880`0855f000   cpuz133_x64 cpuz133_x64.sys Tue Mar 30 22:34:16 2010 (4BB26E58)
fffff880`04d00000 fffff880`04d0e000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`011e1000 fffff880`011ff000   dfsc     dfsc.sys     Tue Jul 14 00:23:44 2009 (4A5BC200)
fffff880`01200000 fffff880`0120f000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`018f1000 fffff880`01907000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`04800000 fffff880`04822000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`04d1a000 fffff880`04d23000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`04d0e000 fffff880`04d1a000   dump_ataport dump_ataport.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`04d23000 fffff880`04d36000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`04cf4000 fffff880`04d00000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`04451000 fffff880`04545000   dxgkrnl  dxgkrnl.sys  Tue Nov 02 02:51:31 2010 (4CCF7CB3)
fffff880`04545000 fffff880`0458b000   dxgmms1  dxgmms1.sys  Tue Nov 02 02:50:56 2010 (4CCF7C90)
fffff880`04994000 fffff880`049bb500   Envy24HF Envy24HF.sys Wed Apr 06 11:07:18 2005 (4253B4D6)
fffff880`046f3000 fffff880`04729000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`01076000 fffff880`0108a000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0102a000 fffff880`01076000   fltmgr   fltmgr.sys   Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`013e8000 fffff880`013f2000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`018b7000 fffff880`018f1000   fvevol   fvevol.sys   Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`0158b000 fffff880`015d5000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff880`04831000 fffff880`0483e000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`03002000 fffff800`0304b000   hal      hal.dll      Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`0458b000 fffff880`045af000   HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`04d8a000 fffff880`04da3000   HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`04da3000 fffff880`04dab080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`04d7c000 fffff880`04d8a000   hidusb   hidusb.sys   Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`04729000 fffff880`047f1000   HTTP     HTTP.sys     Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`015ef000 fffff880`015f8000   hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`03b1f000 fffff880`03b35000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`045ef000 fffff880`045fe000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04dc1000 fffff880`04dcf000   kbdhid   kbdhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00ba9000 fffff800`00bb3000   kdcom    kdcom.dll    Tue Jul 14 02:31:07 2009 (4A5BDFDB)
fffff880`04400000 fffff880`04443000   ks       ks.sys       Thu Mar 04 04:32:25 2010 (4B8F37D9)
fffff880`013bd000 fffff880`013d7000   ksecdd   ksecdd.sys   Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`01560000 fffff880`0158b000   ksecpkg  ksecpkg.sys  Fri Dec 11 06:03:32 2009 (4B21E0B4)
fffff880`04822000 fffff880`04827200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`04dac000 fffff880`04dc1000   LHidFilt LHidFilt.Sys Thu Mar 18 08:51:17 2010 (4BA1E985)
fffff880`04660000 fffff880`04675000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04ddc000 fffff880`04df0000   LMouFilt LMouFilt.Sys Thu Mar 18 08:51:24 2010 (4BA1E98C)
fffff880`04c00000 fffff880`04c23000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c20000 fffff880`00c64000   mcupdate mcupdate.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`04985000 fffff880`04994000   modem    modem.sys    Tue Jul 14 01:10:48 2009 (4A5BCD08)
fffff880`04d36000 fffff880`04d44000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`03ac4000 fffff880`03ad3000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04dcf000 fffff880`04ddc000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00e00000 fffff880`00e1a000   mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`01937000 fffff880`0194f000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`084b8000 fffff880`084e5000   mrxsmb   mrxsmb.sys   Sat Feb 27 07:52:19 2010 (4B88CF33)
fffff880`084e5000 fffff880`08533000   mrxsmb10 mrxsmb10.sys Sat Feb 27 07:52:28 2010 (4B88CF3C)
fffff880`08533000 fffff880`08556000   mrxsmb20 mrxsmb20.sys Sat Feb 27 07:52:26 2010 (4B88CF3A)
fffff880`01809000 fffff880`01814000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f6a000 fffff880`00f74000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`0108a000 fffff880`010e8000   msrpc    msrpc.sys    Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`02c00000 fffff880`02c0b000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`015dd000 fffff880`015ef000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0140e000 fffff880`01500000   ndis     ndis.sys     Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`045e3000 fffff880`045ef000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`046c8000 fffff880`046db000   ndisuio  ndisuio.sys  Tue Jul 14 01:09:25 2009 (4A5BCCB5)
fffff880`03a7a000 fffff880`03aa9000   ndiswan  ndiswan.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`04cbf000 fffff880`04cd4000   NDProxy  NDProxy.SYS  Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`02dbe000 fffff880`02dcd000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02c9f000 fffff880`02ce4000   netbt    netbt.sys    Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`01500000 fffff880`01560000   NETIO    NETIO.SYS    Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`01814000 fffff880`01825000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01400000 fffff880`0140c000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`0304b000 fffff800`03627000   nt       ntkrnlmp.exe Sat Jun 19 05:16:41 2010 (4C1C44A9)
fffff880`0121a000 fffff880`013bd000   Ntfs     Ntfs.sys     Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`01997000 fffff880`019a0000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`04675000 fffff880`046c8000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`02d82000 fffff880`02da8000   pacer    pacer.sys    Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`00fb4000 fffff880`00fc9000   partmgr  partmgr.sys  Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00f74000 fffff880`00fa7000   pci      pci.sys      Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00fde000 fffff880`00fe5000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00fe5000 fffff880`00ff5000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`013d7000 fffff880`013e8000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`08400000 fffff880`084a6000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`049bc000 fffff880`049f9000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c64000 fffff880`00c78000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`03a56000 fffff880`03a7a000   rasl2tp  rasl2tp.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`03aa9000 fffff880`03ac4000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`03bd6000 fffff880`03bf7000   raspptp  raspptp.sys  Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`00c00000 fffff880`00c1a000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`01860000 fffff880`018b1000   rdbss    rdbss.sys    Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`019ea000 fffff880`019f3000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`019f3000 fffff880`019fc000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01800000 fffff880`01809000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`011a7000 fffff880`011e1000   rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`04626000 fffff880`04660000   RMCAST   RMCAST.sys   Tue Jul 14 01:09:14 2009 (4A5BCCAA)
fffff880`046db000 fffff880`046f3000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`03a00000 fffff880`03a56000   Rt64win7 Rt64win7.sys Wed Jun 23 10:10:45 2010 (4C21CF95)
fffff880`084a6000 fffff880`084b1000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`015d5000 fffff880`015dd000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`08d25000 fffff880`08dbb000   srv      srv.sys      Fri Aug 27 04:38:00 2010 (4C773318)
fffff880`08cbe000 fffff880`08d25000   srv2     srv2.sys     Fri Aug 27 04:37:46 2010 (4C77330A)
fffff880`0855f000 fffff880`0858c000   srvnet   srvnet.sys   Fri Aug 27 04:37:24 2010 (4C7732F4)
fffff880`0484e000 fffff880`0484f480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01602000 fffff880`017ff000   tcpip    tcpip.sys    Mon Jun 14 04:39:04 2010 (4C15A458)
fffff880`0858c000 fffff880`0859e000   tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`01843000 fffff880`01850000   TDI      TDI.SYS      Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`01825000 fffff880`01843000   tdx      tdx.sys      Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`02de8000 fffff880`02dfc000   termdd   termdd.sys   Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`005c0000 fffff960`005ca000   TSDDD    TSDDD.dll    Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01011000 fffff880`01023000   umbus    umbus.sys    Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`04d5f000 fffff880`04d7c000   usbccgp  usbccgp.sys  Tue Jul 14 01:06:45 2009 (4A5BCC15)
fffff880`04983000 fffff880`04984f00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`045bc000 fffff880`045cd000   usbehci  usbehci.sys  Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`04c65000 fffff880`04cbf000   usbhub   usbhub.sys   Tue Jul 14 01:07:09 2009 (4A5BCC2D)
fffff880`03b80000 fffff880`03bd6000   USBPORT  USBPORT.SYS  Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`04d44000 fffff880`04d5f000   USBSTOR  USBSTOR.SYS  Tue Jul 14 01:06:34 2009 (4A5BCC0A)
fffff880`045af000 fffff880`045bc000   usbuhci  usbuhci.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00fa7000 fffff880`00fb4000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`019a7000 fffff880`019b5000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`019b5000 fffff880`019da000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00fc9000 fffff880`00fde000   volmgr   volmgr.sys   Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00d96000 fffff880`00df2000   volmgrx  volmgrx.sys  Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`0115b000 fffff880`011a7000   volsnap  volsnap.sys  Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`02ce4000 fffff880`02d79000   vsdatant vsdatant.sys Sun May 09 17:28:58 2010 (4BE6E2CA)
fffff880`02da8000 fffff880`02dbe000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`02dcd000 fffff880`02de8000   wanarp   wanarp.sys   Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`019da000 fffff880`019ea000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e57000 fffff880`00efb000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00efb000 fffff880`00f0a000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02d79000 fffff880`02d82000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00000000 fffff960`00310000   win32k   win32k.sys   Wed Oct 20 04:08:46 2010 (4CBE5D3E)
fffff880`00f61000 fffff880`00f6a000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`03af9000 fffff880`03b1a000   WudfPf   WudfPf.sys   Tue Jul 14 01:05:37 2009 (4A5BCBD1)
fffff880`08dc3000 fffff880`08df4000   WUDFRd   WUDFRd.sys   Tue Jul 14 01:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`08c00000 fffff880`08c71000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01937000 fffff880`01945000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01945000 fffff880`01951000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01951000 fffff880`0195a000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0195a000 fffff880`0196d000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`03af9000 fffff880`03b1f000   tunnel.sys
    Checksum:  00000000
    ImageSize:  00026000
fffff880`02dcd000 fffff880`02dea000   serial.sys
    Checksum:  00000000
    ImageSize:  0001D000
Let us know how things progress. If (when!) you get further blue screens, attach your new dump files and details and we'll move on from there.
scruffy1
Well-Known Member
i'll sort out some of this after work tonight
please note that the envy24 driver is a keeper, as it is the work around to use the wolfson dacs on the rear channels on the chaintech av710 to drive my klipsch speakers - has been the same driver since i got the machine, and never failed me afaik
the catalyst update may be a poisoned chalice, if past experience is correct, but i'll try
zonealarm can go
thx for the pointers, i'll let you know
Elmer
I'm just telling you this so you are aware...
As a rule of thumb, the date for third party drivers to be compatible with Windows 7 is 13 July 2009. Windows 7 is a new operating system. It bears no relation to XP.
Hardware and software designed for XP will not run on Windows 7 unless the Mfr's have updated them to be compatible.
So it might end up bad news. BUT it wasn't mentioned in your dump file...
the catalyst update may be a poisoned chalice, if past experience is correct, but I'll try
Yeah, there were a lot of issues with v10.12 but v11.1 is supposed to have addressed those problems. But you are on a good set, I was just letting you know.
zonealarm can go
Good Choice!!
scruffy1
Well-Known Member
with all respect to your vast knowledge, i link to Link Removed due to 404 Error fyi; feel free to share it with anyone who'd benefit
as in, my drivers are okay ? :confused:
catalyst is a p.i.t.a. even though i love the 5770 for the power miser nature and cool running technology of the 40nm process 5 series - but i was an nvidia fanbois for 8 years or so till last year, and their drivers cause far less pain
Good Choice!!
although z.a. didn't go down without a fight : bsod on running the uninstall until i disabled it with msconfig and then killed it in safe mode... twice counting the tool you linked
die bitch! die :right: and it seems to have fixed the embedded problem
it was largely to save me from nasties behind my firewall on the home network (what with a 16y.o. running feral)
guess i will rely on windoze to protect me... :andwhat:
coretemp is fixed; arcsoft i am considering, but as i use vlc i am not sure it does much for me anyhow
my sincere thanks for your assistance; it has been enlightening to have my windoze cleaned :worship:
Elmer
Everything I've ever learnt was written on the side of a cereal packet!! :D
Yeah, should be fine.
Tenacious bugger aint it!!
Glad to have helped. Any more probs.... You know the routine!!
scruffy1
Well-Known Member
funny you might mention that...
whilst embedded video now plays, it often tells me "adobe player has crashed" and this has occasionally hung firefox briefly, though no bsod ensues
any thoughts on a solution ?
Elmer
TBH, apart from re-installing Adobe Player, err, no. Not using my PC as a media centre type machine, when Adobe player goes awol on me I never really worry about it. I end up just waiting until the Alternate flash updater tells me there's one available and swap them out.
Suppose I ought to read the other side of the cereal packet. : )
cybercore
There was never Catalyst 10.12 WHQL, and as any unsigned driver it had stability issues.
scruffy1
Well-Known Member
Re: ntoskrnl bluescreens... again !
bummer for me, because i am getting adobe flash player has crashed, and a reinstall (of that and firefox, as some people suggested) resulted in a new bsod experience
can we swear here ? i feel an almost overwhelming urge to cuss bigtime :furious:
will upload the palaver if i must, but bluescreen view tells me it's the old ntoskrnl again, and says :
anything this tells me apart from time for a reinstall unless i want to waste a lot of my time
worse still, i have a vista upgrade version for my hardware, but the vendor failed to give me the vista disks (lost by him!) and although i have the win 7 dvd i feel pain is in my future...
kubuntu seems better all the time, if not for my o/c and gaming enthusiasm :yawn:
Elmer
You can do a clean install with Upgrade Media. Courtesy of Link Removed - Invalid URL
cybercore
You'll be getting more and more crashes untill you set the RAM right. You got an 800 Mhz RAM currently running 1068Mhz. In your BIOS setup, set DRAM frequency "Auto" or set 800Mhz. Save and reboot.
Re-attach the new screenshots of CPU-Z memory and SPD per each slot - including for those that are empty.
scruffy1
Well-Known Member
sure
but please note that the ram is team xtreem dark, and rated at 1066 5-5-5-15 despite cpuz's assumptions
also note that it has passed overnight run under memtest without error, and only falls over when using adobe flash in firefox... it can game till the cows come home without issue at the current settings
this has been the case now for close to 2 months since i got the ram, although i confess the e8400 @ 4ghz hasn't been tested on a long run of priming (as it's close to 35c here presently for the next week, that ain't happening anytime soon) only a 20 cycle of LinX, and has been in for the last 6 weeks
the bsod's are a very recent (maybe 2 weeks at the most) phenomenon
i might be under-generous with the vdimm on the ram, but the speeds and latencies are kosher within advertised spec
i find it hard to believe that embedded flash is a harder job for the hardware than hours on medal of honor airborne or ut3, but i accept your thoughts
next time i reboot (likely not tonight unless i am silly enough to watch flash video) i'll tone down the ram and get you the numbers requested (or probably in honesty wind up the vdimm by +0.1v and try my luck again first :razz:)
thanks for your input also; my gut feeling is that it's a driver issue not the very benign overclocking settings i have dialled - 2 hz over stock on the ram is not convincingly cavalier :blink:
maybe i have been ripped off ?
more to follow, no doubt...
follow up edit :
and as you requested -
Link RemovedLink RemovedLink RemovedLink RemovedLink Removed
though the empty slot shots mystify me as to a reason why :confused:
and after i save the changes, i'll try flash... and my money is on another bsod at stock :yawn:
further editing :
ooh! aah ! i stand corrected :worship: stock is fine :redface:
however, in other news, it is equally happy with the vdimm at +0.3v and the speed as before at 1068 with latencies 5-5-5-18 :up: (haven't tried 5-5-5-15)
so i guess the final outcome is don't wimp out of ram voltage appropriate for the speed, especially in hot weather (and it is still over 30c here tonight and nearly midnight)
i should have considered that earlier, but the stability in gaming fooled me
you were right, and get a big thank you for your excellent suggestion :wave:
looks like my next step when it cools down here will be to see if i can get 4100 out of the wolfdale because i thought it was the cpu holding me back :iee:
cybercore
sure
Ok, that clears it up. True that CPU-Z is not always correct, but usually it lists XMP and in your case it doesn't. 1066Mhz is your frequency then. Right now you have it 800Mhz as I asked. If it crashes then set it up according to the rated specs. Sometimes manufacturers make a note that the voltage must be set manually, not auto.
Your gut isn't lying, 2ghz overstock is too much - even if you keep the TDP below 0 the chip will not be stable.
follow up edit :
View attachment 11059View attachment 11056View attachment 11058View attachment 11055View attachment 11057
and after i save the changes, i'll try flash... and my money is on another bsod at stock :yawn:Link Removed
Welcome. Why do I ask for the empty slots? No secret at all, it's been a couple of threads where people would swear they had all sticks the same brand identical and on page 4 it would show they didn't. Some folks occasionally claim they have 1 stick only whereas their CPU-Z shows they have two. Nothing wrong with that, but it's just good to have a clear picture.
Set all the clocks in strict accordance with the manufacturers'. Try out the system for stability for a couple of weeks. Then if it's fine start overclocking again but don't go too high.
scruffy1
Well-Known Member
oops, thx
see my late edit - i hadn't noted your new post when i started my diatribe
thx yet again
true, but i said the ram was 2 hertz over stock :kiss:
although the cpu is (only) 1 ghz over stock (and at less than the vid if i believe cpuz)
however, that's a mere 33% over the rated speed - my opteron 165's quite happily did 50% over their supposed ability, and again this was at around stock volts but under an si120 with good fans (albeit very quietly)
my niche is max overclock at stock volts with good cooling and minimal noise
my current toy looks thus :
scruffy1
Well-Known Member
update :
cooler weather, less ram speed using a different divider (a mere 890 with +0.2v)
however, still had a few bsod's until it would seem a new update by both windoze and adobe has stabilised the system :star:
would i be correct in thinking my hardware is solid but the drivers involved were flakey ? :nerdie:
seems very well behaved under all the usual stresses including embedded flash and gaming (hawx)
comments ?
cybercore
I somewhat doubt this. Although anything is possible.
scruffy1
Well-Known Member
my next step may well be a new install, but i am dreading the experience as i got the system with win 7 on board, and while i can install xp with the mouse tied behind my back (although it is cordless), it would be my first win7 retail install
i played with the rc's
ah well... more procrastination while it's working seems good :ohyea:
cybercore
4ghz is serious, I would still recommend you default clocks. Link Removed
scruffy1
Well-Known Member
pah ! if i wanted to do that i could have stuck with the xeon e3120 at 3.16 stock :yawn:
it was rock stable at 3.8 for 2 years, but the gigabyte ep35-ds3p is a better board than the ds3 variant that came loaded with win 7
4ghz isn't serious... i am barely at stock vcore (which incidentally i notched up one to 1.232v according to cpuz) - and now the weather is cooler again i'm testing it with orthos blend and it is around 50c at 100% load on low fans :cool:
