ako
The Wifi Button on my ACER aspire 4310 lights up when Wifi is disable and the LED is off when it is enable.
does someone knows how to solve this problem?
Tnx
Mitchell_A
Former Moderator
Do you have the latest drivers for your wireless and chipset?
Check the Acer website for the most up-to-date wireless card drivers and chipset drivers. ;)
ako
yes i have the latest drivers(windows update just updated some) and also check out the acer site.. acer site does not list 4310 as compatible to win 7, i dont know why.
Mitchell_A
Former Moderator
Is there Vista drivers? I'd install the most recent drivers for your chipset for Vista, they should still be compatible with Windows 7. :D
ako
if all the drivers is updated, what else can I do? is there a hack or something to fix this? all other things are fine, except for the LED, it is just bugging me.. :)
