robmars83
I bought a computer a year ago and was never able to defrag it because for some reason the C: drive would never show up. So googled my issue and found something about checkdisk utility Heres the thread:
Anyway, as you can see, it went as wrong as it can go... It told me I needed to schedule the check for the next restart so I did. I restarted my computer and now it just says BOOTMGR is Missing. I've read other threads about this and none of them help me at all.. I have no installation or recovery disks since windows 7 was on my computer when I bought it new... Someone PLEASE help me.
xdad2010
Don't be panic bro.it's very easy to solve.What OS did u install?D u have that recovery disk with u?Just insert disc if u don have u can use usb flash, restart with that command and press f9 and choose the OS .then language comes after that do repair.then restart finish bro.
Video is here YouTube - Fixing BOOTMGR is missing Error While Trying to Boot Windows Vista
Hope it helps u :-)
