No display on Dell E6510 Led display, hook up external monitor and system comes up properly. I shine a bright light on laptop display and can see a very dim display on the screen. Is this a backlight issue, not sure if this exists on a led display. Any idea on troubleshooting this issue?
The thread discusses a Dell E6510 laptop with a non-visible display despite an external monitor working, with the original poster suspecting a backlight issue. The responder confirms it likely is a backlight problem—common causes include the inverter or CCFL in older models—and explains that since the display is LED backlit, it might involve different components such as an LED driver instead. Overall, the discussion clarifies that the issue is related to the backlighting, and repair options are accessible and potentially inexpensive.
Similar threads
- Article
- Article
- Article
- Locked
- Solved
