Angro
The problem, that i described Link Removed - Invalid URL but the only one cares. The Problem: Videocard didnt want to detect! Link Removed (The sreenshot is on russian, but i think you'll understand) When I am trying to install driver for my card it's saying: No NVIDIA Device detected, GTFO
I heard many of the tales (?) about The-Good-Windows Seven, but i never thought that it wont detect my VGA!
My Hardware
Motherboard ASUS M2A-VM
Videocard ASUS EN8600 GT Silent
RAM 3 GB
Proccesor AMD Athlon x64 3800+
Windows 7 x64 Ultimate
The drivers on Chipset are installed! The Gamer OSD is installed! The utilites from ASUS are installed! I don't know what to do, please, need advice
And sorry for mistakes, i am Russian :)
It seems like you are encountering an issue with your NVIDIA graphics card not being detected on Windows 7 x64 Ultimate. Let's troubleshoot this problem step by step:
Troubleshooting Steps for NVIDIA Graphics Card Detection Issue:​
  • Check Physical Connections:
  • Ensure that your graphics card is properly seated in the PCI-E slot on your motherboard.
  • Verify that the power connectors to the graphics card are securely connected.
  • BIOS Settings:
  • Check your BIOS settings to confirm that the PCI-E slot is enabled and set as the primary display adapter.
  • Driver Installation:
  • Download the latest NVIDIA drivers for your ASUS EN8600 GT Silent graphics card from the official NVIDIA website. Make sure to...
  • BIOS Settings:
  • Download the latest NVIDIA drivers for your ASUS EN8600 GT Silent graphics card from the official NVIDIA website. Make sure to download the correct drivers for Windows 7 x64.
  • Before installing the drivers, it's recommended to uninstall any existing graphics card drivers.
  • Safe Mode Installation:
  • Try installing the NVIDIA drivers in Safe Mode. Sometimes, installation in Safe Mode can resolve driver conflicts.
  • Device Manager:
  • Open Device Manager in Windows and check if the graphics card is listed under "Display Adapters." If it's not listed or if there's an error icon, there may be a hardware issue.
  • Driver Signature Enforcement:
  • Disable Driver Signature Enforcement temporarily before installing the NVIDIA drivers. This can sometimes help with driver installation issues.
  • Compatibility Mode:
  • Right-click on the driver installer, go to Properties, and under the Compatibility tab, try running the installer in compatibility mode for an older version of Windows like Windows XP or Windows Vista.
  • Update Windows:
  • Make sure Windows 7 is fully up to date with all the latest updates and service packs. Sometimes, Windows updates can resolve driver-related issues.
System Information:​
  • Motherboard: ASUS M2A-VM
  • Graphics Card: ASUS EN8600 GT Silent
  • RAM: 3 GB
  • Processor: AMD Athlon x64 3800+ By following these steps, you should be able to troubleshoot the issue of your NVIDIA graphics card not being detected on Windows 7 x64 Ultimate. Let me know if you need further assistance or if you encounter any specific errors during the troubleshooting process. Good luck!
