Matthew Davis
okay basically, i want to install World of Warcraft onto my laptop. i did it before fine, then i uninstalled it and 6 months later i want to install it again. (i go through phases)
but when i put the installation disc in, it doesn't autorun, and when i go to open the dvd-rom, it gives me a list of 'installation tomes' labelled 1 to 6. i have tried putting other discs in to see if it was just my WoW disc, but none of these discs work either. i've tried uninstalling the dvd-rom drive and reinstalling it. and i've checked the registry for any errors. any help would be greatly appreciated.
cybercore
Hello and Welcome,
If it stopped reading all disks all of a sudden then it probably bit the dust and you need to replace it. But first do some basic testing:
PC Troubleshooting CD Rom DVD Drive
CD/DVD Diagnostic
Matthew Davis
hi i've just tried it now, and nothing, it reads discs, but the installation files don't work on them and the autoplay doesn't wok either :/
helpifIcan
Fantastic Member
I think at some point an MS update disabled the autoplay. I'm not sure if it can be enabled. You might do some searching to see if my memory of this is correct.
