The thread discusses ongoing background audio noise issues experienced during online radio recording on a Windows 7 PC, with the noise worsening during higher display activity and network usage. The original poster has tried multiple troubleshooting steps, including driver updates and disabling network adapters, without success. Contributors suggest checking audio enhancements, verifying hardware configurations, and considering physical interference or sound card alternatives, but no definitive solution is provided, indicating the problem remains unresolved.
Deckky
Honorable Member
I often record programmes from on-line radio but they are marred with constant audio noises in the background consisting of pops, clicks crackles and whistles. It seems to be worse when there's processor and network activity (like when recording) and appears to change when the display changes (noisier when the more detail there is on the screen). E.g. if you open a folder the sound goes kkkkk as the folder opens. I've tried to update the drivers but Device Manger says they're the most up to date available. I've also tried different power saving settings and disabled the processor throttling, some help a fraction but the noise is always there. I even tried disconnecting the mains earth to try and eliminate any earth loops but it made no difference. I did a latency check on the drivers and although it's high on ndis.sys, disabling the network adapter to eliminate the problem means I can no longer record anything (and with the adapter disabled there's still noise on the audio). Can anyone advise please as I'm nearly bald with all the hair tearing.
Sent from my iPad using WindowsForum
Deckky
Honorable Member
Thread Author #21
Even though I had made countless Google searches before posting this I found nothing that worked, mainly suggesting things like latency issues, power settings and bios settings. It was suggestions on here that made me think about possible inherent noise issues on my specific motherboard and video card and it was first looking up noise on the P6T came up trumps. Thanks all.
Fixer1234
It's admirable that you attempted to research this on your own and took such an active role in troubleshooting (and actually were the one to find the answer). That's often not the case. My comment about starting with a search referred to me and other advice-givers on the forum.
