The thread discusses a user’s issue with running a batch script to turn off Nanoleafs on Windows shutdown, which works manually but not automatically during shutdown. After troubleshooting via Event Viewer and Task Scheduler, the user discovers that placing the script in the logoff folder instead of the shutdown folder ensures it executes correctly. The overall sentiment is one of resolution after some experimentation and guidance from a helpful responder.
TomNXT
Hello, so i added my batch script for auto turning off nanoleafs on pc shutdown via this tutorial Executing a batch script on Windows shutdown but it does not work, if you run the script alone, it works fine, but not on windows shutdown... any ideas? Its added in a shutdown folder and also linked via "add" button
Neemobeer
Windows Forum Team
Have you looked at the event viewer to see if there is an error message? Does the script execute from the task scheduler? Do you have it set to execute on shutdown or logoff? Both are different events.
TomNXT
Thread Author #3
in task scheduler it works, if i go to gpedit to scripts there is only Shutdown and Startup options no logoff and this is meant to work for shutdown, event viewer i dont know how to check i never worked with it
edit: ok ihave looked into the event viewer and there are no errors referring to my batch script, i converted it to .exe file, again it works if i open it but not on shutdown if i add it into scripts section
Neemobeer
Windows Forum Team
If you're trying to do with with a GPO you will want to enable GPO tracing & logging and examine that log for errors
Neemobeer
Windows Forum Team
It's a gpo setting
