muchovoxx
Hi there. I've had this issue before, but this time i want to know how to fix it... without using Acer eRecovery. Im having these miscoloring, at white spots and black spots on my screen there is cyan and red instead. Ive tryed to scan a couple of times. With my normal AntiVirus = Kaspersky Pure and with Avast Free antivirus. which i unistalled.
I am using the Acer Aspire 7745g with Windows 7 Home edition
Hello and welcome to the forum.
My first suggestion would be to determine which display adapter is installed in your laptop and then go here Link Removed due to 404 Error and download and install the correct driver and see if that clears up the issue. If it does then you will probably need to prevent the Windows Update Utility from installing hardware driver updates on your computer.
Regards
Randy
Trouble
Noob Whisperer
Regards
Randy
Medico
This might very well be a graphics driver proble. If the Acer site does not provide a good driver check at the graphics card manufacturer's site. Perhaps they will have an updated driver.
