auyhre
Honorable Member
How do I enable sound for remote desktop connections connecting to Windows 7? I found out how to do it in Windows Server 2003, by clicking Terminal Service Configuration in Administrator Tools, and turning sound on there. I can't find Terminal Service Configuration in Windows 7, and I can't figure out how to do it.
Thanks in Advance.
Hi there
I don't think this has changed at all from the way XP and Vista client computers do it.
On the CLIENT computer (you don't need to set up anything on the remote machine unless it's say Windows 2003 server where you need to enable sound on the remote machine in the first place and enable it to accept remote connections..
Start RDP (accessories ==> remote desktop connection).
Then Options==>local resources==>remote computer sound ==>bring to this computer.
You can also enable your local files to be accessible in the remote session by clicking More==> drives (and plug and play devices if you want those as well).
cheers
jimbo
jimbo45
Hi there
cheers
jimbo
auyhre
Honorable Member
Thanks for your reply. That got everything working.
