roller
I am having problems searching for documents on Windows 7. Just cannot seem to find some despite following Microsoft search procedure - it isn't working for me!
Can anyone please tell me a basic way to try to find downloads that seem to have disappeared! I can only find a few and I know there are lots more. I have tried typing in a name in the Start search box and the search box at the top right hand page of documents, downloads, pictures - nothing.
roller
Thank you
Roller
I’m a great fan of the built in Windows search in Explorer. There are a number of searches that can be made: Here are a few examples:
A minimum file size, simply type size:>30,000KB into the Search box and press Enter.
type:=.pdf or type:=.doc will display specific file types.
filename:x will display files using a partial filename. x represents the partial filename you want to search for.
kind:video, kind:music, kind:pictures or kind:docs will find all the videos, music, pictures or documents.
Providing the location is indexed, you can search in Windows Explorer for a specific word or phrase by typing content: followed by your phrase enclosed in double quotes. This will produce a list of files matching the criterion.
Speed...
Trouble
Noob Whisperer
Hello roller and welcome to the forum.
Most of the time when we get a question such as yours, you'll get some suggestions about third party search tools such as
My recommendation http://www.voidtools.com/
And Mike H's usual recommendation http://www.mythicsoft.com/agentransack
I know it is kind of a pain to install a third party program for these types of things but either or both are far superior to anything Microsoft has embedded in their OS since XP
As with any third party freeware installation, be sure and perform a custom / advanced install and avoid any bloatware that may be part of the installer.
BurrWalnut
Roller
Speed up the search by opening Windows Explorer at the folder you want to search, rather than at the root folder. Also, pressing F3 will show Search options like Date Modified and Size.
Pauli
Fantastic Member
I've used http://www.snapfiles.com/get/TextCrawler.html and
http://www.snapfiles.com/get/bkreplace.html
They are both text replacement tools, but work very well in search too - you can't replace unless you find the original? Still, I haven't got a clue how they would work out for you.
http://www.snapfiles.com/downloadfind.php?st=search&action=s&offset=0&lc=1&searchsort= has dozens of programs in this field.
As usual, to make a question only provides more work. I do hope you find yours.
