follower4Christ New Member Joined Dec 28, 2012 Messages 2 Dec 28, 2012 Thread Author #1 Hello, I need some advice - I'm trying to fix this any ideas? thanks! ~ Link Removed
Solution patcooke Dec 29, 2012 Looks more like a roblem with the modem/router than the wireless adapter. Is your pc showing as "connected" to the router? Has the router previously worked but now stopped or is it a new one? Go to programs, accessories, command prompt, run it and enter the following command: ipconfig /all SPost the output on here and we can help analyse the problem better.
patcooke Microsoft MVP Microsoft MVP Joined May 16, 2010 Messages 5,688 Dec 29, 2012 #2 Looks more like a roblem with the modem/router than the wireless adapter. Is your pc showing as "connected" to the router? Has the router previously worked but now stopped or is it a new one? Go to programs, accessories, command prompt, run it and enter the following command: ipconfig /all SPost the output on here and we can help analyse the problem better. Upvote 1 Downvote Solution
Jimbo22 Essential Member Joined Aug 27, 2008 Messages 5,035 Dec 29, 2012 #3 Sometimes just unplugging the modem/router from the AC outlet for one minute and then plugging it back in will do the trick. Upvote 0 Downvote
