Glenn Angel
Hi ppl.
I recently had BSODs and freezes. I was under the impression these were related. I found that the BSOD was a driver related to a logitech camera, which i ahve unistalled.
I have since completed accidently stumbled upon "summary page events" in event viewer and have noticed all these errors were when ive been having these complete system freezes...
THis is the error and ive had the SAME error about 30 times now over a 2.5 week period:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2011-07-19T13:23:02.947223700Z" />
<EventRecordID>50352</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>BIG</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
Does anyone have a clue how i can fix this issue?
I ubilt my own PC. It is not overclocked and it runs very coolIm having 0 bsod's at all!
Glenn
Ps. thanks for any help :)
Glen Angel
Hi and welcome
Event ID 41 kernel power often means a driver is taking far too long to respond and the computer is forced quit. Please run driver verifier to find out which
I'd suggest that you first backup your stuff and then make sure you've got access to another computer so you can contact us if problems arise. Then make a System Restore point (so you can restore the system using the Vista/Win7 Startup Repair feature).
In Windows 7 you can make a Startup Repair disk by going to Start....All Programs...Maintenance...Create a System Repair Disc - with Windows Vista you'll have to use your installation disk or the "Repair your computer" option at the top of the Safe Mode menu .
Then, here's the procedure:
JMH
Glen Angel
Hi and welcome
- Go to Start and type in "verifier" (without the quotes) and press Enter
- Select "Create custom settings (for code developers)" and click "Next"
- Select "Select individual settings from a full list" and click "Next"
- Select everything EXCEPT FOR "Low Resource Simulation" and click "Next"
- Select "Select driver names from a list" and click "Next"
Then select all drivers NOT provided by Microsoft and click "Next"
- Select "Finish" on the next page.
Reboot the system and wait for it to crash to the Blue Screen. Continue to use your system normally, and if you know what causes the crash, do that repeatedly. The objective here is to get the system to crash because Driver Verifier is stressing the drivers out. If it doesn't crash for you, then let it run for at least 36 hours of continuous operation (an estimate on my part).
If you can't get into Windows because it crashes too soon, try it in Safe Mode.
If you can't get into Safe Mode, try using System Restore from your installation DVD to set the system back to the previous restore point that you created.
Please post the file or files found in C/windows/minidump as we can read this to see what the issue is. If you find that no files are in said folder or the folder is missing then you'll need to configure your machine to produce them when it blue screens. See screenshot:
Link Removed due to 404 Error
Glenn Angel
ok so ive got a crazy problem!
What ive done:
"what you said"
Restarted and blue screen crash.
Restarted and option for "normal startup" or "repair (recommended"
-Normal startup : crash and back to reboot
-Repair: "could not be repaired -> send to microsoft"
-restore: "could not restore - error"
Im now at work so i cant do anything for another 2.5 hrs but thats as far as i am...
Im ok with wiping my C drive as its my SSd and is windows only, however how can i get to a bootup stage and turn off the verifier thing?
nmsuk
Will it boot into safe mode with networking? Once in safe mode run verifier.exe to disable it. After it's disabled could you post any new minidumps from safe mode.
Glenn Angel
Yeh not to be sarcastic (coz im not!) but as i said before it comes up wiht "normal mode" or "repair windows"
It doesnt give me the option or selection for safe mode or safe with networking or anyhintg.
I can take a photo of the screen if needed.
Prior to this i can access bios and get into boot menu etc but thats the only pages i can get to.
I understand the page i WANT to get to... but it never leads me there.
:) Any other ideas?
In repair screen i can access memtest and Cmd.exe
Is there any way i can use CMD to turn verifier off?
nmsuk
When you turn your macihine on, press F8 repeatedly this should allow you to select safe mode. If you can get to a cmd yes, running verifier.exe /reset will let you disable it.
Glenn Angel
ok. Done. Im now in Saf mode with networking. LOL at crazy 480x640 screen on my 24" screen :P
now ive attached all my DMP files. BUT there are none from today when the pc crashed on startup 3 times. There are only dmps from earlier when i was having an issue with my logitech webcame (now uninstalled)
So.. do i keep verifier on or off? Should i just keep usig in safe mode?
If i use in safe mode... doesnt that mean the cause of this is not running thus my BSOD wont appear?
Ill do w/e is requested :P
just so you know, when my pc tried to repair itself i got a msg regarding:
Cant repair
Signature 1: 6.1.760016385
Signature 2: " as above "
Signature 3: unkown
Signature 4: 64
Signature 5: autofailover
Signature 6: 1
Signature 7: Bad drive (or driver.. i cant read my writing)
Locale ID 1033
Dont know if that helps.. but thats all ive got to work with!Link Removed
Elmer
Hi Glenn.
STOP 0x0000009F: DRIVER_POWER_STATE_FAILURE
Usual causes:
Device driver
Your latest dump file lists lvuvc64.sys Sat May 12 00:59:12 2007 as the probable cause. This is a Logitech Web Cam driver.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
(In a couple of dumps a windows system usb driver was blamed. rest as above.)
As a Priority:
LVUSBS64.sys Sat May 12 01:01:20 2007
lvuvc64.sys Sat May 12 00:59:12 2007 Link Removed Update.
The sptd.sys driver is notorious for causing BSOD's with Windows 7. It's a driver used and installed along with Daemon Tools and Alcohol 120 which you'll also have to uninstall.
Then use the correct (32bit or 64bit) download from Link Removed to uninstall the SPTD.SYS driver.
Make sure to select the uninstall button! DO NOT SELECT INSTALL!!
AVG is known to be a cause of BSOD's on Windows 7 systems. Suggest that you uninstall it. Download the correct Link Removed for your system (32 or 64 bit).
If you have AVG ID protection installed, download the AVGID Protection Remover from the above link as well (it wouldn't hurt to download and run it anyway). Download BSOD friendly Link Removed due to 404 Error as AVG's replacement. Uninstall AVG through the Control Panel. Re-boot to Safe Mode and run the AVG Removal tool(s). Re-boot to normal mode and install MSE. Make sure your Windows firewall is enabled!
hamachi.sys Thu Feb 19 10:36:41 2009
lmimirr.sys Tue Apr 10 23:32:45 2007
LMIRfsDriver.sys Mon Jul 14 17:26:56 2008
RaInfo.sys Fri Jan 04 18:57:14 2008 LogMeIn/RemotelyAnywhere. Has known issues with Windows 7. Update or uninstall this software.
Bugcheck Analysis:
BugCheck 9F, {3, fffffa800ad30a00, fffff80000b9c3d8, fffffa800d5d7550}
*** WARNING: Unable to verify timestamp for lvuvc64.sys
*** ERROR: Module load completed but symbols could not be loaded for lvuvc64.sys
Probably caused by : lvuvc64.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa800ad30a00, Physical Device Object of the stack
Arg3: fffff80000b9c3d8, Functional Device Object of the stack
Arg4: fffffa800d5d7550, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
IRP_ADDRESS:  fffffa800d5d7550
DEVICE_OBJECT: fffffa800a2f2bd0
DRIVER_OBJECT: fffffa8009cc1830
IMAGE_NAME:  lvuvc64.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  46450350
MODULE_NAME: lvuvc64
FAULTING_MODULE: fffff8800ae8f000 lvuvc64
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
STACK_TEXT:
fffff800`00b9c388 fffff800`035029c2 : 00000000`0000009f 00000000`00000003 fffffa80`0ad30a00 fffff800`00b9c3d8 : nt!KeBugCheckEx
fffff800`00b9c390 fffff800`034a1652 : fffff800`00b9c4d8 fffff800`00b9c4d8 00000000`00000001 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x34a90
fffff800`00b9c430 fffff800`034a14f6 : fffffa80`069f72c8 fffffa80`069f72c8 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`00b9c4a0 fffff800`034a13de : 00000005`ef815bca fffff800`00b9cb18 00000000`00027e58 fffff800`0360bd88 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00b9caf0 fffff800`034a11c7 : 00000001`f77a78c3 00000001`00027e58 00000001`f77a7837 00000000`00000058 : nt!KiTimerExpiration+0x1be
fffff800`00b9cb90 fffff800`0348da2a : fffff800`03608e80 fffff800`03616cc0 00000000`00000001 fffffa80`00000000 : nt!KiRetireDpcList+0x277
fffff800`00b9cc40 00000000`00000000 : fffff800`00b9d000 fffff800`00b97000 fffff800`00b9cc00 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0x9F_3_IMAGE_lvuvc64.sys
Drivers:
fffff880`0bf39000 fffff880`0bf64000   000      000.fcl      Fri Sep 26 14:11:22 2008 (48DCDF7A)
fffff880`05508000 fffff880`05546000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`0102f000 fffff880`01086000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`04689000 fffff880`04712000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`055ea000 fffff880`05600000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`012e1000 fffff880`012ec000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`0556c000 fffff880`055b4000   aqw8cicj aqw8cicj.SYS Sun Nov 28 10:38:44 2010 (4CF23134)
fffff880`04651000 fffff880`04658000   AsrAppCharger AsrAppCharger.sys Fri Jun 11 07:37:12 2010 (4C11D998)
fffff880`0c937000 fffff880`0c942000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00fae000 fffff880`00fb7000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fb7000 fffff880`00fe1000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff960`00830000 fffff960`00891000   ATMFD    ATMFD.DLL    Sat Feb 19 09:00:32 2011 (4D5F86B0)
fffff880`045b1000 fffff880`045f8000   avgldx64 avgldx64.sys Thu Jun 03 22:06:48 2010 (4C081968)
fffff880`04649000 fffff880`04650080   avgmfx64 avgmfx64.sys Sun Apr 25 22:06:15 2010 (4BD4AEC7)
fffff880`01880000 fffff880`0188c0c0   avgrkx64 avgrkx64.sys Thu Feb 11 03:52:44 2010 (4B737F0C)
fffff880`04400000 fffff880`04451000   avgtdia  avgtdia.sys  Wed Apr 27 08:34:54 2011 (4DB7C71E)
fffff880`018cc000 fffff880`018d3000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`04638000 fffff880`04649000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`0b58a000 fffff880`0b5a8000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`007a0000 fffff960`007c7000   cdd      cdd.dll      Sat Nov 20 12:55:34 2010 (4CE7C546)
fffff880`0168b000 fffff880`016b5000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00cc5000 fffff880`00d85000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01850000 fffff880`01880000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00c67000 fffff880`00cc5000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00d85000 fffff880`00df7000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`055d3000 fffff880`055e3000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`0b472000 fffff880`0b47b000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 13:33:36 2010 (4CD94DB0)
fffff880`0ae27000 fffff880`0ae35000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0461a000 fffff880`04638000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`0460b000 fffff880`0461a000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`0183a000 fffff880`01850000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`06344000 fffff880`06366000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`063b2000 fffff880`063f5000   dtsoftbus01 dtsoftbus01.sys Thu Jan 13 08:27:08 2011 (4D2EB75C)
fffff880`0ae41000 fffff880`0ae4a000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0ae35000 fffff880`0ae41000   dump_ataport dump_ataport.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0ae4a000 fffff880`0ae5d000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`0ae1b000 fffff880`0ae27000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`0ff07000 fffff880`0fffb000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`0f200000 fffff880`0f246000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0626c000 fffff880`06275c00   EtronHub3 EtronHub3.sys Fri Jan 28 21:46:45 2011 (4D433945)
fffff880`05488000 fffff880`05497c00   EtronXHCI EtronXHCI.sys Fri Jan 28 21:46:43 2011 (4D433943)
fffff880`044a7000 fffff880`04566000   Ext2Fsd  Ext2Fsd.SYS  Thu Feb 10 08:13:46 2011 (4D539E3A)
fffff880`05546000 fffff880`05553000   fdc      fdc.sys      Tue Jul 14 01:00:54 2009 (4A5BCAB6)
fffff880`01338000 fffff880`0134c000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`012ec000 fffff880`01338000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`018d3000 fffff880`018dc000   FNETURPX FNETURPX.SYS Sat Oct 04 03:27:02 2008 (48E6D476)
fffff880`015dd000 fffff880`015e7000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01800000 fffff880`0183a000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01ae5000 fffff880`01b2f000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`0555f000 fffff880`0556c000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`039ff000 fffff800`03a48000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`0f246000 fffff880`0f251000   hamachi  hamachi.sys  Thu Feb 19 10:36:41 2009 (499D3639)
fffff880`013b6000 fffff880`013da000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`0ac9d000 fffff880`0acf9000   HdAudio  HdAudio.sys  Sat Nov 20 10:44:23 2010 (4CE7A687)
fffff880`04496000 fffff880`044a7000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`0c94e000 fffff880`0c957000   hiber_atapi hiber_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0c942000 fffff880`0c94e000   hiber_ataport hiber_ataport.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0c957000 fffff880`0c96a000   hiber_dumpfve hiber_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`0ae6b000 fffff880`0ae84000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0ae84000 fffff880`0ae8c080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`0ae5d000 fffff880`0ae6b000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0b4c1000 fffff880`0b58a000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01bcf000 fffff880`01bd8000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`055bd000 fffff880`055d3000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`015e7000 fffff880`015f6000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`0ad4c000 fffff880`0ad5a000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00bc1000 fffff800`00bcb000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`0636b000 fffff880`063ae000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`015b1000 fffff880`015cc000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01660000 fffff880`0168b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`063f5000 fffff880`063fa200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`063ae000 fffff880`063b1d80   LGBusEnum LGBusEnum.sys Tue Nov 24 01:36:48 2009 (4B0B38B0)
fffff880`0c8c3000 fffff880`0c8c5480   LGVirHid LGVirHid.sys Tue Nov 24 01:36:48 2009 (4B0B38B0)
fffff880`0adcf000 fffff880`0ade4000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`055e3000 fffff880`055ea000   lmimirr  lmimirr.sys  Tue Apr 10 23:32:45 2007 (461C108D)
fffff880`0b482000 fffff880`0b495000   LMIRfsDriver LMIRfsDriver.sys Mon Jul 14 17:26:56 2008 (487B7E50)
fffff880`0ad5a000 fffff880`0ad7d000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`0ad16000 fffff880`0ad20900   LVUSBS64 LVUSBS64.sys Sat May 12 01:01:20 2007 (464503D0)
fffff880`0ae8f000 fffff880`0b1ff500   lvuvc64  lvuvc64.sys  Sat May 12 00:59:12 2007 (46450350)
fffff880`00c04000 fffff880`00c53000   mcupdate mcupdate.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`0ad3e000 fffff880`0ad4c000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`062f8000 fffff880`06307000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`0ad21000 fffff880`0ad2e000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00f94000 fffff880`00fae000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`0b5a8000 fffff880`0b5c0000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`0b5c0000 fffff880`0b5ed000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`0b400000 fffff880`0b44e000   mrxsmb10 mrxsmb10.sys Wed Apr 27 03:39:40 2011 (4DB781EC)
fffff880`0b44e000 fffff880`0b472000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`04566000 fffff880`04571000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`011f5000 fffff880`011ff000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01358000 fffff880`013b6000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`04600000 fffff880`0460b000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01bbd000 fffff880`01bcf000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0124c000 fffff880`012d9000   mv91xx   mv91xx.sys   Fri Oct 01 04:27:07 2010 (4CA5550B)
fffff880`012d9000 fffff880`012e1000   mvxxmm   mvxxmm.sys   Fri Oct 01 04:26:49 2010 (4CA554F9)
fffff880`016b8000 fffff880`017ab000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`05424000 fffff880`05430000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`01200000 fffff880`0122f000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`06278000 fffff880`0628d000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`04741000 fffff880`04750000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`04451000 fffff880`04496000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01600000 fffff880`01660000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`04571000 fffff880`04582000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`047ed000 fffff880`047f9000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03416000 fffff800`039ff000   nt       ntkrnlmp.exe Sat Apr 09 05:15:23 2011 (4D9FDD5B)
fffff880`0140e000 fffff880`015b1000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`018c3000 fffff880`018cc000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`0ff02000 fffff880`0ff07000   nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`06298000 fffff880`062c5000   nvhda64v nvhda64v.sys Tue May 10 10:41:18 2011 (4DC9083E)
fffff880`0f254000 fffff880`0ff02000   nvlddmkm nvlddmkm.sys Sat May 21 05:07:04 2011 (4DD73A68)
fffff880`0471b000 fffff880`04741000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00ef7000 fffff880`00f0c000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00ec4000 fffff880`00ef7000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00f7d000 fffff880`00f84000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00f84000 fffff880`00f94000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`015cc000 fffff880`015dd000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0be45000 fffff880`0beeb000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0ad2e000 fffff880`0ad3e000   point64  point64.sys  Fri Apr 08 23:58:14 2011 (4D9F9306)
fffff880`06307000 fffff880`06344000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c53000 fffff880`00c67000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`0134c000 fffff880`01357e00   PxHlpa64 PxHlpa64.sys Wed Jun 24 00:16:35 2009 (4A416253)
fffff880`0b47b000 fffff880`0b482000   RaInfo   RaInfo.sys   Fri Jan 04 18:57:14 2008 (477E818A)
fffff880`05400000 fffff880`05424000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`0122f000 fffff880`0124a000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`013da000 fffff880`013fb000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`00fe1000 fffff880`00ffb000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`0479c000 fffff880`047ed000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`01bf6000 fffff880`01bff000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`017d0000 fffff880`017d9000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`017d9000 fffff880`017e2000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01b83000 fffff880`01bbd000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`0ade4000 fffff880`0adfc000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05498000 fffff880`05508000   Rt64win7 Rt64win7.sys Mon Mar 21 13:20:32 2011 (4D8750A0)
fffff880`0ac00000 fffff880`0ac0c000   RtNdPt60 RtNdPt60.sys Mon Jul 20 03:27:32 2009 (4A63D614)
fffff880`01000000 fffff880`0102f000   SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`0beeb000 fffff880`0bef6000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`05553000 fffff880`0555f000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`04750000 fffff880`0476d000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`01b7b000 fffff880`01b83000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0108a000 fffff880`011ec000   sptd     sptd.sys     Tue Nov 23 11:47:37 2010 (4CEBA9D9)
fffff880`0c82b000 fffff880`0c8c3000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`0bf64000 fffff880`0bfcd000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0bef6000 fffff880`0bf27000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`06369000 fffff880`0636a480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`018e1000 fffff880`01ae5000   tcpip    tcpip.sys    Mon Apr 25 03:37:30 2011 (4DB4DE6A)
fffff880`0bf27000 fffff880`0bf39000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`045a4000 fffff880`045b1000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`04582000 fffff880`045a4000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`04788000 fffff880`0479c000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00400000 fffff960`0040a000   TSDDD    TSDDD.dll    Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`04658000 fffff880`0467e000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`06200000 fffff880`06212000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`0ae00000 fffff880`0ae1ac80   usbaudio usbaudio.sys Sat Nov 20 10:43:52 2010 (4CE7A668)
fffff880`0acf9000 fffff880`0ad16000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`06276000 fffff880`06277f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`017e2000 fffff880`017f3000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`06212000 fffff880`0626c000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`05432000 fffff880`05488000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`00eb7000 fffff880`00ec4000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01bd8000 fffff880`01be6000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`017ab000 fffff880`017d0000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00f0c000 fffff880`00f21000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00f21000 fffff880`00f7d000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01b2f000 fffff880`01b7b000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`0476d000 fffff880`04788000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01be6000 fffff880`01bf6000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e04000 fffff880`00ea8000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ea8000 fffff880`00eb7000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`04712000 fffff880`0471b000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`00373000   win32k   win32k.sys   Sat Jun 11 04:06:57 2011 (4DF2DBD1)
fffff880`055b4000 fffff880`055bd000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`011ec000 fffff880`011f5000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`0ad7d000 fffff880`0ad9e000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`0ad9e000 fffff880`0adcf000   WUDFRd   WUDFRd.sys   Sat Nov 20 10:43:32 2010 (4CE7A654)
Unloaded modules:
fffff880`0c8c6000 fffff880`0c937000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0188d000 fffff880`0189b000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0189b000 fffff880`018a7000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`018a7000 fffff880`018b0000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`018b0000 fffff880`018c3000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`062db000 fffff880`062e6000   LVUSBS64.sys
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`062d0000 fffff880`062db000   LVUSBS64.sys
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`062c5000 fffff880`062d0000   LVUSBS64.sys
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`0628d000 fffff880`06298000   LVUSBS64.sys
    Checksum:  00000000
    ImageSize:  0000B000
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`06338000 fffff880`06369000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`06307000 fffff880`06338000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Elmer
Missed an important bit. Sorry!
Turn off Driver Verifier for now!
Glenn Angel
ok so ive uninstalled all the above including with the exclusion of hamachi and logmein.
Uninstalled AVG and done remover. Installing MS antivirus on reboot.
Ive still got verifier going.. so ill leave that running?
Im GOING to uninstall hamachi and logmein if i get more BSODs etc, except i need them often and use them heaps so i dont want to take them off yet! (but im not overlooking your suggestion)
will post back again in a sec
ps. I downloaded the stpd thing for daemon tools, but after uninstalling daemon tools it said i have no stpd on my computer
Elmer
Do a search for it. Most of the time DT leaves it behind.
Turn of verifier and see if you have problems.
In a Run... window or command prompt, type verifier /reset
Glenn Angel
righteo
STPD is now removed :)
Daemon removed
AVG removed
MSE installed and updated
STILL getting the freeze on boot with verifier on (just so you know)
Will run for a few days with no verifier and see if it crashes.
The logitech drivers were already uninstalled (i checked on driver view)
Attached is a jpg of a video of the BSOD that came up when pc crashed on startup with verifier still on.
So now verifier is off, and ill just see if i get more dmp files.
ps. how can i make the forum auto-log me on from facebook! it doesnt remmeber me each time
nmsuk
Not sure about the auto login with facebook. I got around it by changing my password in this sites user cp and using it and my account name to log in instead.
Elmer
@Glenn FYI.
STOP 0x0000001E: KMODE_EXCEPTION_NOT_HANDLED
Usual causes:
Device driver, hardware, System service, compatibility, Remote control programs, memory, BIOS.
Glenn Angel
MMM ok then ill give memtest a go.
Im sure its part of my driver error or "unknown" error thats causing issue, but im having a black screen after welcome, before desktop for about 30 secs still...
Ive heard this may occur if i have a solid background, whihc i dont. i have a cycling jpeg background.
Ive also head this may occur if i have mapped drives on network that are off??? I do actuall ahve this. I have a NAS that only turns on at 2pm every day... Perhaps ill test if my PC has black screen when NAS is on...
It didnt ahve this issue in safe mode from memory.
Can i run memtest with both RAM in... then if i get an error do one at a time? If i have no errors then i can assume both RAM's are ok?
Thanks for the continued help guys, i appreciate it
Glenn Angel
@Glenn FYI.
Usual causes:
ps. my bios is up to date. Does logmein count as a remote control program?
Ive had hamachi and logmein for 2 months b4 issues started.. not taht that means they arent causing, but just so you know
Glenn Angel
ok it has been suggested ;
"Set maximum wait time for the network if the user has a roaming user profile or remote home directory to 0"
In my GPO however as a home user I cant access GPO :( is there a registry setting that will make my pc stop looking for the mapped drives if they arent turned on?
