The thread discusses the impact of charging habits on Toshiba Satellite laptops with Windows 10, particularly concerning charging up to 80% versus 100%. Participants agree that modern batteries are less prone to memory effects, and keeping the laptop plugged in generally doesn't harm the battery, especially with smart charging technology. Overall, the discussion suggests that maintaining a charged state and avoiding frequent full discharges can help preserve battery longevity, with some noting that old batteries still perform adequately for several years.
Hermitkrab
I have a Toshiba Satellite laptop, L55 series, Windows 10 Anniversary OS. This laptop, and my previous Toshiba, stops battery charging at 80%. I imagine this promotes battery longevity. That being the case, is it desirable to regularly run on battery only until it's almost run down, or does that not make a difference? Thanks.
Pat's right about that for the most part. Laptop batteries begin to lose their Mojo after 1 year or so; some will last as much as 5 years and keep an 85% charge or better for at least a couple of hours (long enough to watch a DVD or streaming movie like Netflix or Amazon Prime/Fire. I usually have my Customers replace their laptop batteries >1 yrs if there is any degradation below a 2 hr. charge hold time. In other words, if you can't want an entire movie on your existing laptop battery without plugging it into your MAINS (Wall Outlet), it's for sure shot and time to replace it. That's my Rule of Thumb on that.
Best,:nerdie:
<<<BIGBEARJEDI>>>
patcooke
Microsoft MVP
Microsoft MVP
Modern batteries don't suffer from the "memory" problems which earlier ones did. I'm very cavalier with mine - It's plugged into the mains more ofen than not and only runs on the battery as and when I've no access to mains. I cannot remember ever having to replace a battery (maybe I'm just lucky.)
Hermitkrab
Thread Author #3
Thanks, Pat. So, does charging to 80% better than 100%, as far as the battery goes?
BIGBEARJEDI
Best,:nerdie:
<<<BIGBEARJEDI>>>
Hermitkrab
Thread Author #5
Thanks, Pat & bigbear. I mostly use my PC plugged in, but still want to keep the battery in the best possible shape. On my particular Toshiba laptop the entire bottom cover needs to be removed for battery replacement. My older Toshiba had a battery compartment that was easily accessible. Anyhow, my battery probably won't be harmed by keeping the PC plugged in most of the time, or so I'm gathering from this discussion.
patcooke
Microsoft MVP
Microsoft MVP
I'm sure it will be the least of your computer worries - my lifelong experience as a computer professional is that Sod's Law rules supreme but I press on always believing my glass to be half full!
Neemobeer
Windows Forum Team
Yeah I leave all my laptops plugged in all the time. Many of them today are smart enough to stop charging when full. Besides that, most laptop batteries I've seen are around $40 so not a huge investment if you do need to replace one.
