The thread discusses issues with sound and USB recognition on a Toshiba Satellite L505d-GS6000 running Windows 7 after a reinstall. The original poster's main concern is the missing audio driver, with device manager showing a yellow exclamation mark, and no sound device detected, despite attempts to install drivers from the Toshiba website and generic sources. Responses suggest troubleshooting steps such as uninstalling and re-detecting drivers, checking device error messages, and verifying USB device recognition, but the underlying issue remains unresolved.
adamf4i
Not sure if this is the right section but any help would be greatly appreciated
Basically I reinstalled windows 7 on my toshiba laptop I got from someone model is satellite l505d-gs6000
For some reason I have no sound it acts like theres a problem when you clikc on the sound icon which looks muted
I have downloaded everything I can find on toshiba site to try and get audio driver installed but no luck at all ,
In device manager it just shows yellow exclamation mark next to high definition audio controller
Anyone have some kind of generic driver that would work and enable sound to start working , sound devices show no audio device installed
THanks, in advance
Hi
First thing I would try is...
Right click on the device in Device Manager.
Click Properties and see if there is a message about the error.
I.e. Device is Missing etc.
Next Right Click and select Uninstall.
When that's done reboot your computer and force Windows to re-identify reinstall and look for drivers again.
If that doesn't work come back with the error message, maybe that will be a clue as to whats going wrong.
This seems to be a common issue with this computer, lot of complaints not many answers.
Mike
MikeHawthorne
Hi
Mike
Adamsappleone
U.S.Navy D.A.V.
Hello adamf4i, Link Removed to Windows 7 Forums,
These should be the drivers you need;
Link Removed due to 404 Error
Hope this helps
Don
adamf4i
Thread Author #4
Hope this helps
Don
STill not luck with trying all the drivers on the manfacture website , any more suggestions ?
adamf4i
Thread Author #5
Any other suggestions for this as to why its not working , Also when plugging in my iphone or a usb drive into usb ports nothing is coming up no lights on the usb drive or anything ??
MikeHawthorne
Can you read the USB drives in Windows Explorer?
Did you try uninstalling and letting Windows reinstall the Sound Device?
When you open the Sounds windows what do you see there?
What is the selected playback option?
Did it have an error message in Device Manager?
adamf4i
Thread Author #7
Yep , no device when you click on the sound icon in the bottom right taskbar
