The thread discusses a user experiencing issues with their Windows PC automatically assigning a default gateway even when set to DHCP, requiring manual deletion each time they connect to WiFi. The user has attempted commands like ipconfig /release and /flushdns without success. Respondent suggests sharing the IP configuration details for further troubleshooting.
prince2886
Hi
I need to assign an ip address automatically in wifi network of my windows pc to connect different wireless . but my PC is assigning constant default gateway even a change my network setting to DHCP. it make me to delete the default gateway manually each and every time when i need to connect WiFi.
i tried many run commands like ipconfig /renew ,ipconfig /release and ipconfig /flushdhs command to delete the default gateway cache. but still i am having issue.
below i attached the screenshot of the IP configuration
patcooke
Microsoft MVP
Microsoft MVP
You need to display the content of your ipconfig so we can see what is supposed to happen. You may copy and paste it into a post or output ipconfig to a text file and attach it.
