Hey guys I just built my PC today everything is working fine but when I was installing Windows 10 it said "No device drivers found" and I have no idea what the problem is. In the BIOS it said that I do have my HDD and my SSD, the only thing I can think that might have caused the problem is the optical drive because I took it off of an older PC or my motherboard can't run Windows 10 (It's a Fatal1ty z97 MOBO by the way) any help will be greatly appreciated!
The thread discusses a Windows 10 installation issue where the user receives a "No device drivers found" error despite BIOS recognizing the HDD and SSD. Several users suggest possible solutions, including checking the installation media, trying a different optical drive or using a USB drive, and manually installing drivers. Overall, the conversation indicates that the problem is likely due to driver or media issues rather than hardware incompatibility, and multiple troubleshooting steps are recommended.
Similar threads
- Solved
