The thread discusses issues with Windows' built-in Backup & Restore app not allowing the user to initiate an HDD backup, as the 'Proceed' button remains greyed out despite selecting the correct external drive. The original poster confirms the external drive is detected and formatted correctly, but the problem persists when trying to back up using Windows' native tool. A suggestion is made to try alternative backup software, such as Macrium Reflect, Acronis TrueImage, or EASUS Todo, as Windows' own backup utility is known to be unreliable in Windows 10.
Ed1944
Well-Known Member
I'm trying to make an image of my HDD in my Toshiba L55 laptop. I have a 1TB external drive connected. When the dialogue box asks what type of media I'm using, I select the proper answer (external hard drive). After doing that, the button I'm supposed to select in order to start the process is greyed out. What could be the problem? Thanks in advance for your help.....Ed
Unfortunately, the built-in W10 Backup & Restore app does NOT work reliably in W10. We've done 2 years of testing both here on this forum and 3 others I volunteer on, AND many of us also happen to be Windows Insiders; the folks who help tested W10 from it's Tech Preview days.
Try one of these 3 instead:
1.) Macrium Reflect
2.) Acronis TrueImage
3.) EASUS Todo
I have the Macrium installed on close to 80 computers including about 8 of my own. It's also protecting several Customers who run their businesses on their computers or laptops. I have a very high success rate in restoration; 99% or better assuming the hardware on the machine is not faulty.
Gotta go,
Good luck,:encouragement:
<<<BIGBEARJEDI>>>
nmsuk
Can you select local HDD and then select which external it uses?
Hermitkrab
The external drive shows up correctly as drive F. The drive has been totally formatted and shows as empty in 'properties'.
nmsuk
At any point does it tell you the size of the backup? I can't see why it'd grey out the proceed button. What backup application is this or is it the built in windows backup?
Ed1944
Well-Known Member
Thread Author #5
Ed1944
Well-Known Member
Thread Author #6
IIt's Windows own app, the one originally for W7 "Backup & Restore". I didn't see where I was asked what size the backup was, but I would hope a 1 TB drive would be sufficient.
Ed1944
Well-Known Member
Thread Author #7
In retrospect, the window showed the capacity of the external drive: just a tiny bit below 1 TB. The only time the proceed button isn't greyed out is if I select the option to backup to the cloud, which I don't want.
BIGBEARJEDI
1.) Macrium Reflect
3.) EASUS Todo
Gotta go,
<<<BIGBEARJEDI>>>
Hermitkrab
Hermitkrab
1.) Macrium Reflect
3.) EASUS Todo
Gotta go,
<<<BIGBEARJEDI>>>
Hermitkrab
Thanks, Big Bear. I'll explore those options you mentioned. BTW, did you know there's an area, including a lake, just outside Los Angeles called "Big Bear"?
BIGBEARJEDI
You betcha! Glad to help.:up:
And yes, I live in Big Bear valley area in Southern California; bought a place up here 6 years ago to retire in after vacationing here for 30 years and am enjoying it tremendously!:ohyea: I created my username after moving here. I even have a California license plate "BBRJEDI". :D
Here's a photo of our lake:
An image from 'problem imaging HDD'. A winding river runs through a lush forested valley surrounded by mountains under clear skies.
<<<BBJ>>>
