wootnow
Operating system: Windows 2.6.0.6001 (SP 1)
CPU type: Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz
CPU Speed (GHz): 2.02
System memory (GB): 3.998
Graphics card model: NVIDIA GeForce GTX 260M
Graphics card driver: nvd3dum.dll
Desktop resolution: 1366x768
Hard disk size (GB): 285.397
Hard disk free space (GB): 227.738
My Asus computer is automaticly disabling the Dvd rom drive when its turned off and back on. It forces me to go into device manager and enable it every time i want to burn a cd or use the drive at all. any ideas as to how to fix this
It appears that your Asus computer is automatically disabling the DVD-ROM drive whenever it is turned off and back on, requiring you to manually enable it in Device Manager every time you want to use the drive. This issue can be frustrating, but there are a few troubleshooting steps you can try to resolve it:
Possible Solutions to Fix DVD-ROM Drive Disabling Issue:​
  • Update DVD-ROM Drive Driver:
  • Check if there are any updated drivers for your DVD-ROM drive. Sometimes outdated drivers can cause such issues. You can update the driver through Device Manager or by visiting the manufacturer's website.
  • Check Power Settings:
  • Make sure that power settings are not causing the DVD-ROM drive to be disabled...
  • Make sure that power settings are not causing the DVD-ROM drive to be disabled. Sometimes, power-saving settings can lead to devices being turned off to save power. Adjusting power settings may help.
  • BIOS Settings:
  • Access the BIOS settings of your computer and check if there are any settings related to device power management. Ensure that the DVD-ROM drive is not set to be disabled during system boot.
  • Windows Settings:
  • Look into Windows settings related to device management and power settings. Ensure that there are no options enabled that might be causing the DVD-ROM drive to be disabled.
  • Check for Software Conflicts:
  • Sometimes, third-party software or conflicts with other drivers can cause issues with hardware devices. Check for any recent software installations that might coincide with when the issue started.
  • Hardware Check:
  • It's also worth physically checking the connections between the DVD-ROM drive and the motherboard to ensure everything is secure and properly connected.
  • Windows Update:
  • Ensure that your system is up to date with the latest Windows updates. Sometimes, updates can resolve compatibility issues.
  • System Restore:
  • If the issue started recently, you can try performing a system restore to revert your system to a point where the issue was not present.
Additional Tips:​
  • After trying the above steps, restart your computer to see if the issue persists.
  • Keep an eye on any error messages or events in the Event Viewer related to the DVD-ROM drive for more insights. By following these steps, you may be able to troubleshoot and fix the automatic disabling of your DVD-ROM drive on your Asus computer. Let me know if you need further assistance or if you encounter any specific errors or messages during this process.
