The thread discusses an issue where uninstalling programs with Iobit Uninstaller and subsequent system restore resulted in missing registry keys and incomplete program listings. The original poster seeks help in recovering these registry entries after the cleanup. Responders suggest reinstalling missing programs to regenerate registry entries and mention that the problem may be due to CCleaner's utility, implying that a system cleanup might have damaged the registry or installer folders.
chamatht
Please help Me............(sorry for my english)
This fault is occur a after using Iobit Uninstaller. I closed this program before uninstrallation process of selected programs completed. After this only 5 programs are showing. I restore syatem by Iobit Uninstaller. but no any change.
I checked registry (HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall). There is only 5 keys. How do I recover these registry keys.
Please HELP ME..........................
I would reinstall any of the programs which are not showing. This will restore any registry entries which are missing and entries in the start programs menus.
patcooke
Microsoft MVP
Microsoft MVP
Elmer
Pats advice is spot on. Think of it as doing a repair install.
Somehow your C:\Windows\Installer folder has been virtually emptied by a clean up program most likely.
chamatht
Thread Author #4
I Used CCleaner's uninstall utility,It shows all programs which are installed. Is there a other solution for this problem
