JeffCodeblum
I have heard of this behavior from various people using various applications. It seems to happen more with 32-bit apps running on new Windows versions.
The program opens and immediately closes. It is only runs for a second or less. I have tried turning off data execution prevention which does not help. I am thinking maybe a security feature of Windows is shutting down my software application.
The program in question is an older 32-bit application which I am developing some updates for. It accesses the network and creates servers. It is written in C and C++. I have tried it on Windows 7, Server 2008, and Server 2012. So far it only runs in XP.
I would greatly appreciate any help with this project as I am running out of ideas.
Did you check the event log? Start -> Run -> compmgmt.msc -> Event Viewer
Looks for errors here. Obviously, compatibility mode may give it a go. Try running it with UAC, as it may require these prompts, and its not happening. See if that doesn't crash it.
Mike
Windows Forum Admin
JeffCodeblum
Thank you for the quick response. I forgot to mention that I am running it in compatibility mode for Windows XP service pack 3. Thanks for the advice on the event log I will research more on how to use it on my own. I will also try UAC and get back to you. Thanks again.
