homertgww
Hey everyone,
Just to be clear on what kind of motherboard I'm using and the onboard audio in said motherboard, here's the model number: GA-M57SLI-S4 (AMD - socket AM2)
and the onboard audio is by Realtek. The mobo itself is a bit outdated I guess, at about 4-5 years now.
I listen to a lot of music and also dabble in FLStudio, so the ability to hear both the left and right channels is super important for me.
The problem I'm facing is that even after installing the drivers/codecs for Realtek HD audio several times from the Gigabyte support site, automatic updates or other driver downloads, this happens:
When I set the audio balance to center, I only hear the left channel audio - but in both ears on headphones or both sides on speakers. Setting the balance to 100% left gives the same effect as mentioned with center balance, while setting the balance to 100% right yields no sound in the right channel, actually no sound at all.
It seems that I'm either going to have to fork over some extra cash for a proper sound card, wait till Realtek gets real with their drivers, or just live hearing the left side of everything :P
I've looked at dozens of posts regarding audio problems but they seem unique to each system mentioned. I've even run tests on the control panel for the left and right channels with the same result - there's audio on the left, none on the right. Upon checking the device manager, there seems to be no problems detected.
I'm not expecting a solution to this anytime soon, but I'd like to know if there are others out there with the exact problem and if they were able to solve it. If I happen to miraculously figure out how to fix it I shall post over this for anyone else in my situation.
Cheers,
H
It seems like you're facing a challenging audio issue with your motherboard's onboard Realtek audio. Here are a few suggestions and insights to help you troubleshoot and potentially resolve the problem you're experiencing:
Troubleshooting Steps:​
  • Check Physical Connections:
  • Ensure that your audio cables are securely connected to the correct ports on your motherboard.
  • Reinstall Audio Drivers:
  • Sometimes, simply reinstalling the audio drivers can resolve such issues. Make sure to download the latest drivers directly from the Realtek website and perform a clean installation.
  • Windows Audio Settings:
  • Verify that your Windows audio settings are correctly configured.
  • Check the balance settings in...
  • Check the balance settings in the Sound Control Panel to ensure they are properly centered.
  • Realtek Audio Control Panel:
  • Use the Realtek Audio Control Panel to check for any advanced settings that might be affecting the audio balance.
  • BIOS Settings:
  • Check your BIOS settings to see if there are any audio-related configurations that could be causing the issue.
  • External Audio Device Testing:
  • Test your headphones/speakers on another device to rule out any issues with the external hardware itself.
  • Alternative Audio Output:
  • You can also try using a USB external sound card as a temporary solution to see if the issue lies with the onboard audio or the drivers.
Further Considerations:​
  • Considering your usage in music production, investing in a dedicated sound card could significantly enhance your audio experience and offer more control over audio output.
  • Keep an eye out for any updated drivers or firmware releases from Realtek or Gigabyte in the future that might address this issue. Should you require further assistance or find a solution to your problem, feel free to update this thread to help others experiencing similar audio challenges. Best of luck in resolving this issue! If you need any more guidance or have any other questions, feel free to ask.
