The thread discusses how to rearrange shortcut positions within a folder on Windows 7 desktop and how to fix the default globe icon on internet shortcuts. The responses explain that shortcuts can be moved by dragging within the folder and that icons can be customized through shortcut properties, including changing icons and replacing website favicons by creating new shortcuts with the correct URL. The overall sentiment indicates helpful guidance for managing shortcut organization and appearance on Windows 7.
Marios
Active Member
Can i change a position of a shortcut on Windows 7 inside a folder that is been used as program execution place on the screen desktop? If yes then how? Also when i create a shortcut from a link on the internet, the shortcut has is own icon from the company on the internet but when i store it in a folder on desktop, a globe
icon appears (a windows 7 default icon). What should i do to fix it?
To change the position of a shortcut within a folder on your Windows 7 desktop and customize its icon, you can follow these steps:
Changing Shortcut Position:​
  • Open the Folder: Navigate to the folder on your desktop where you want to change the position of the shortcut.
  • Rearrange the Shortcuts: Click and drag the shortcut to move it within the folder. You can place it in a desired position by dragging it to the spot you want.
Customizing Shortcut Icons:​
  • Changing Shortcut Icons:
  • Right-click the Shortcut: Right-click on the shortcut for which you want to change the icon.
  • Select "Properties": Choose "Properties" from the context menu.
  • Change Icon: In the...
  • Change Icon: In the Properties window, go to the "Shortcut" tab and click on the "Change Icon" button.
  • Choose an Icon: Browse for the icon you want to use or select from the available options.
  • Apply and Save: After selecting the new icon, click "OK" to apply the changes.
Fixing Icons for Internet Shortcuts:​
  • Download Favicon: For Internet shortcuts, the icon displayed is usually the website's favicon. To get the proper website icon:
  • Visit the Website: Open the webpage the shortcut is linked to.
  • Copy the URL: Copy the URL of the webpage from the address bar.
  • Convert to Shortcut: Right-click on the desktop, choose "New," and then "Shortcut."
  • Paste URL: Paste the URL and complete the wizard. This will create a new shortcut with the correct website icon.
  • Organize: Move the new shortcut into the desired folder. By following these steps, you can adjust the position of shortcuts within a folder on your desktop and customize their icons to suit your preferences.
