A user seeks assistance in getting sound on a second monitor connected via HDMI to a Windows 8.1 PC, facing challenges despite the picture displaying correctly. Responses suggest ensuring the HDMI output is selected in playback devices and checking for proper drivers, with the user later confirming that a new cable fixed the sound issue. However, after troubleshooting, the user reports that although sound works, the display on the second monitor now only shows the wallpaper, indicating a possible configuration issue.
john45h
Hi all
PC connected by cable to TV as 2nd monitor. Windows 8.1. Picture fine but how do I get sound on 2nd monitor?
If you have an HDMI output, it should show in the Playback Devices on the sound Panel. If you do not show anything, you may need a driver for that device.
You may need the HDMI cable plugged in to see the options. You are not sending sound anywhere else? You system may be able to deliver different sound from the front or back ports, but I don't think it can support two sound sources at the same time from the back.
Saltgrass
Since you are probably using an HDMI cable to connect the TV, you may need to set the sound up to use the HDMI output.
john45h
Thread Author #3
Thanks Saltgrass - not sure how to do this !! On 8.1 any attempt to manage audio devices brings up Realtek screen showing "Properties" as "Realtek High Definition Audio" but no sound on 2nd monitor still. No mention of HDMI in control panel audio screens. Default shown as 24 bits 48000Hz
Saltgrass
john45h
Thread Author #5
Will also check cable. 5+ yrs old. ?Maybe does not support sound !!?
john45h
Thread Author #6
New lead resolved sound issue but I have obviously done some unintentional alteration via the Control Panel as I now receive sound from e g BT Sport download but the picture on the second monitor is my wallpaper !! Help !!
