The thread discusses a user experiencing random, strange sounds on their Windows 10 Acer laptop, with several community members suggesting malware scans and examining recent installations as potential causes. The original poster temporarily resolves the issue but continues to experience it, prompting further suggestions like monitoring sound processes. A later contributor shares a similar persistent sound problem linked to their 5.1 speaker setup and resolves it by adjusting their speaker configuration, indicating hardware compatibility may play a role. Overall, the thread reflects troubleshooting efforts with mixed success, emphasizing both software and hardware considerations.
streunR
Member
Hey, i really need help with this terrible strange sound.
Vocaroo | Voice message
It comes totally random, tested with and without headset.
Cant find this in "systemsounds"
Really need to fix it..
Acer Laptop / windows 10
By the way, the sound is still there...
You could try tracking it down by uninstalling all your third party applications such as media players or pdf readers and just leave windows as well as it's drivers installed. A process of elimination.
If the sound does stop then slowly start adding apps back one at a time to see if the sound returns. If your sure things are ok then install the next thing and so on..
Excellent! So far so good.. I'll keep my fingers crossed.. 🙂
Neemobeer
Windows Forum Team
It's likely being played from a file, so you could leave procmon running with a filter for create/open operations and only for music file types.
ddrnic
Banned
Hi. I have had presided problem after installing, even win7. Then I hit win10 and it was remain after new installation of windows.
What was. I have 5.1 speakers. They was connected in 5.1 mode. Every time while rebooting or turning off it was that ugly peachy sound.
Solution was after long two years(not drivers issue) I have found. I reconnected 5.1 to 7.1 and that was it. My sound system is 10 years old electronics. Maybe cos of that.
Good luck.
