StephDragon
Member
- Joined
- Feb 22, 2018
- Messages
- 42
Hi guys,
Some of you may have seen my other posts before. Indeed it's another issue to add to the long series of problems I've got with my Toshiba Satellite P50-C. It was my first expensive laptop, the fastest I ever got (16go ram) but it's now not really usable. So in short, it was bought around 2.5 / 3 years ago; after 5 months first issues with the wifi adapters, had to buy an external dongle one; a month ago webcam became unresponsive and yesterday the ethernet-lan connection stopped working. No way to get ethernet-internet, even when changing cables, plugging to a different router's port... The ethernet sign had also disappeared from the windows taskbar. Shame, because it's the only way I can get fast internet and I use the laptop for work.
So trying to solve the webcam and ethernet issues in one go, I did a factory reset and a fresh Windows install for the first time since I bought that machine. All I can say is that it yielded no results whatsoever. I tried support on the Toshiba website and they suggested going into device manager, uninstalling the lan card, which I did, and restarting. Now that lan card has even disappeared from the device manager's list. I did a network adapters reset but to no avail as well.
The laptop is still a fast machine but with no internet I am thinking about buying a cheap cr*p laptop since it seems price doesn't mean quality haha. Please share your thoughts and ideas... Could the laptop still be repaired?
