My desktop icons and text look blurry. it looks like it is opened in safe mode or like the icons are zoomed in. Here is what I have checked so far, checked to see if it is safe mode, resolution, display setting, icon size. any thoughts on what it could be.
The user reports blurry, zoomed-in-looking icons and text on their HP Omni100PC desktop. After initial troubleshooting, the responder suggests it may be a resolution issue, noting that the all-in-one model likely lacks monitor buttons for auto or reset functions, and recommends adjusting display settings accordingly. The overall tone is helpful and focused on guiding the user through potential display resolution fixes to resolve the blurriness.
Ok so it's an all-in-one It may not have those monitor buttons. You may simply have a weird resolution set.
Go to step 5 of the fuzzy /blurry screen section
Thank you for your response but I do not have an auto button on the monitor and I don't know how to reset or set to default. Sorry I am not that computer savvy.Press the auto button on the monitor or go into the menu and select reset or 'set to default'
HP Omni100PCWhat model is the monitor. There should be a sticker on it somewhere or the model will be listed on the bezel.
