grummann
Hello,
I'm having a specific problem with XP Mode. When I change the size of XP Mode window it instantly get me logged off. After I change the size I have to login again in to XP mode. I mean It's a silly problem, couldn't find any solution anywhere, or anything remotely similar, so it might be I'm doing something wrong. These are specs of PC:
System Information
Operating System: Windows 7 Enterprise 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
System Manufacturer: INTELR
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz (2 CPUs), ~700MHz
Memory: 3072MB RAM
Available OS Memory: 3070MB RAM
Page File: 1344MB used, 4794MB available
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
Display Devices
Card name: Radeon X300/X550/X1050 Series (Microsoft Corporation - WDDM)
Manufacturer: ATI Technologies Inc.
Chip type:
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_5B63&SUBSYS_1490174B&REV_00
Display Memory: 1405 MB
Dedicated Memory: 126 MB
Shared Memory: 1279 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor Name: BenQ FP91G+ (Digital)
Monitor Model: BenQ FP91G+
Monitor Id: BNQ76A6
Native Mode: 1280 x 1024(p) (60.020Hz)
Output Type: DVI
Driver Name: atiumdag.dll,atiumdva.cap,atitmmxx
Driver File Version: 8.14.0010.0630 (English)
Driver Version: 8.56.1.15
DDI Version: 9Ex
Driver Model: WDDM 1.0
Driver Attributes: Final Retail
Driver Date/Size: 7/14/2009 02:14:55, 4030976 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71EE2-1823-11CF-8D76-9A34A1C2C535}
Vendor ID: 0x1002
Device ID: 0x5B63
SubSys ID: 0x1490174B
Revision ID: 0x0000
Driver Strong Name: atiilhag.inf:ATI.Mfg.NTx86...1:ati2mtag_RV370:8.56.1.15:pci\ven_1002&dev_5b63
Rank Of Driver: 00F42001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
If there's any other info you need just say it. Thanks in advance.
It sounds like you're encountering a frustrating issue with XP Mode where changing the window size results in being logged off. Let's explore some troubleshooting steps for this problem.
Possible Solutions:​
  • Integration Features: Ensure that the integration features between Windows 7 and XP Mode are functioning correctly. Sometimes, issues with these features can cause unexpected behavior like automatic logouts.
  • Display Settings: Check the display settings within XP Mode. It's possible that the resolution or display settings are causing the logout issue. Try adjusting the display settings to see if that resolves the problem.
  • Virtual Machine Settings: Verify the settings of the virtual machine itself...
  • Virtual Machine Settings: Verify the settings of the virtual machine itself. There might be a configuration related to window size or display that needs adjustment.
  • Updates: Ensure that Windows 7, XP Mode, and any relevant drivers are up to date. Outdated software can sometimes lead to compatibility issues.
  • BIOS Update: Consider checking if there are any BIOS updates available for your system (AWRDACPI) that could potentially address compatibility issues with virtualization. Your computer specifications seem adequate for running XP Mode, but resolving this issue may require tweaking certain settings or updating software components. Do you need guidance on specific steps for any of the solutions listed above? Feel free to ask for more detailed instructions if needed.
